Adding an x-offset to 2d image plots
I'm trying to plot my data as 2d image plots as shown in the sample pdf file I've attached. We have a measurement related drift in x direction which increases in y-direction. I would like to center this graph around 0 to have a symmetric plot. Until now I have only found the setscale command which rescales the whole 2d matrix. I need to rescale each of the waves of the 2d matrix by adding an offset.
Is that possible in a 2d image plot or do i need to take a different approach?
Thanks a lot!
Consider resampling the image using a conversion from the 2D matrix to XYZ (MatrixToXYZ), modify the X's for the offset, and then use XYZtoMatrix.
#include <MatrixToXYZ>
#include <XYZtoMatrix>
JimProuty wrote: Consider resampling the image using a conversion from the 2D matrix to XYZ (MatrixToXYZ), modify the X's for the offset, and then use XYZtoMatrix.
Thanks for the quick response.
Although the MatrixtoXYZ allows me to create the needed waves the reconversion loses a lot of data. Although I use the right amount of rows/columns I get a triangular image instead of a rectangular one.
