Getting Peak results from Multi-peak fit in a function
I am thinking can I access the variables which store the multi-peak fit (version 2.0) results after the iterations ; in a function after every iteration. I am trying to make a new wave out of the locations & area of the several peaks in a spectra. (Strategy is to run the function after the multi-peak fit, and then after every subsequent fit for different peaks out there , to access those variables. I am not sure it will work !)
I am using Igor Pro 6.35
Thank you for replies (I hope to get some).
October 20, 2014 at 08:15 am - Permalink
October 20, 2014 at 01:35 pm - Permalink
October 20, 2014 at 07:06 pm - Permalink
