WaveList based on a range of number
I'd like to make (and display) a list of waves based on the range of integers (suffix) in the wave name:
say, the names of my waves are as follows: "test_a4_350", "test_a4_351", "test_a4_352", ..., "test_a4_850".
How can I make a list of wavenames that includes only waves from "test_a4_380" to "test_a4_450"?
Thanks very much!
ListOfWaves(380, 450)
to get a string list of wave names ending in values from 380 to 450 and including the end points.
August 27, 2014 at 06:35 am - Permalink
ListOfWaves("test_a4_", 380, 450)
August 28, 2014 at 12:13 am - Permalink
Your codes definitely solved my problem! Thanks so much for your generosity and wisdom. I also learned a bit about how to optimize my igor code from reading yours.
August 29, 2014 at 08:23 am - Permalink
One other thing to keep in mind is that both functions operate only on the current folder.
I like kanekaka's solution... a good example of thinking outside the box.
August 29, 2014 at 08:35 am - Permalink
