A simple panel for statistical comparison of two 1D waves
This does the statistical comparisons on two 1D waves with the outputs to a notebook. It first computes the mean, sem, and number of points of the waves selected, then do the normality test, variance test then the statistical test using t-test (pair and unpaired), K-S test, or Wilcoxon Signed Rank Test based on the normality and variance tests. Finally it will calculate the effect size using Cohen's d. It is wrote in a rush, and the waves selection panel is just a copy-and-paste of the waveselector example procedures. But my colleagues like it and suggest to share this, I guess their main reason is that now all the statistical analyses go to one notebook, and they no longer need to frantically click the close button to close.
#include <WaveSelectorWidget>
Function Make2WaveSelectorPanel()
    String panelName = "WaveSelectorExample"
    // figure out what to show in the Wave Selector, and make an appropriate name for the panel
            panelName+="Waves"
    if (WinType(panelName) == 7)
        // if the panel already exists, show it
        DoWindow/F $panelName
        // doesn't exist, make it
        NewPanel/N=$panelName/W=(181,179,471,510) as "Wave Selector Example"
        // list box control doesn't have any attributes set on it
        ListBox ExampleWaveSelectorList,pos={9,13},size={273,241}
        // This function does all the work of making the listbox control into a
        // Wave Selector widget. Note the optional parameter that says what type of objects to
        // display in the list.
        MakeListIntoWaveSelector(panelName, "ExampleWaveSelectorList", content = WMWS_Waves)
            PopupMenu sortKind, pos={9,270},title="Sort Waves By"
            MakePopupIntoWaveSelectorSort(panelName, "ExampleWaveSelectorList", "sortKind")
        // This is an extra bonus- you can create your own function to be notified of certain events,
        // such as a change in the selection in the list.
        WS_SetNotificationProc(panelName, "ExampleWaveSelectorList", "ExtExampleNotification", isExtendedProc=1)
        // To support this demo, provide a button that displays this code
        Button Gr2Comp,pos={9,300},size={110,20},proc=gr2stat_0,title="2 Group"
        Button GrPairComp,pos={130,300},size={110,20},proc=gr2stat_1,title="Pair"
Function gr2stat_0(ba) : ButtonControl
    STRUCT WMButtonAction &ba
    switch( ba.eventCode )
        case 2: // mouse up
            comp2(1)// click code here
            break
            break
    endswitch
Function gr2stat_1(ba) : ButtonControl
        case 2: // mouse up
            comp2(3)// click code here
            break
            break
    endswitch
Function comp2(p2)
    variable p2
    string w_sed = WS_SelectedObjectsList("Waveselectorexamplewaves","ExampleWaveSelectorList")
    string x1_n = StringFromList(0, w_sed)
    string x2_n = StringFromlist(1, w_sed)
    wave x1 = $x1_n
    wave x2 = $x2_n
    sn_nb();Append2SN_TS()
    Append2SN("*" + x1_n + ":\r mean = " + num2str(mean(x1)) + " sem = " + num2str(sqrt(variance(x1)/numpnts(x1))) + " n = " + num2str(numpnts(x1)))
    Append2SN("*" + x2_n + ":\r mean = " + num2str(mean(x2)) + " sem = " + num2str(sqrt(variance(x2)/numpnts(x2))) + " n = " + num2str(numpnts(x2)))
    if (p2 == 1)
        Append2SN("*** Compare 2 waves ***")
        cmp2(1, x1, x2)
    elseif (p2 == 3)
        Append2SN("*** Compare paired waves ***")
        cmp2(3, x1, x2)
    ENDIF
END
Function Append2SN_TS() //Time Stamp
    Variable stampDateTime = 1 // nonzero if we want to include stamp
    Variable tnow
   String stamp
    Notebook StatNote selection={endOfFile, endOfFile}
    tnow = datetime
    stamp = Secs2Date(tnow,0) + ", " + Secs2Time(tnow,0)
    Notebook StatNote text="\r" + "****" + stamp + "****\r"
Function Append2SN(str) //Add Log
    String str
    Notebook StatNote text= str+"\r"
Function sn_nb()
    if (WinType("StatNote") == 5)
        // if StatNote already exists, show it
        DoWindow/F StatNote
        newnotebook /n=StatNote /F=1 as "Stat Results Note"
    ENDIF
END
Function effect_size(x1, x2)
    wave x1, x2
    variable cohen_s_d = abs(mean(x1) - mean (x2))/sqrt((variance(x1) + variance(x2))/2)
    Append2SN("*Effect Size:\r  Cohen's d = " + num2str(cohen_s_d) + " (d = 0.2, small; 0.5, medium; 0.8, large)")
END
Function cmp2(p2, x1, x2)
    variable p2
    wave x1, x2
    statsjbtest/Q x1
    wave W_JBResults
    variable nd_x1
        if (W_JBResults[3] < W_JBResults[5])
            Append2SN("x1 is Normal distribution")
            nd_x1 = 1
            Append2SN("x1 is not normal")
            nd_x1 = 0
        ENDIF
    statsjbtest/Q x2
    wave W_JBResults
    variable nd_x2
            nd_x2 = 1
            nd_x1 = 0
        ENDIF
    statsvariancestest/Q x1, x2
    wave W_statsVariancesTest
    variable nd_xs
        if (W_statsVariancesTest[2] < W_statsVariancesTest[3])
            Append2SN("x1, x2 variance same")
            nd_xs = 1
            Append2SN("x1, x2 variance NOT same")
            nd_xs = 0
        ENDIF
    variable p2w_con = (nd_x1==1 && nd_x2==1 && nd_xs==1)
    variable p2_final = p2 + p2w_con
    variable hs_rn = (CaptureHistoryStart())
    switch(p2_final)
        case 2:
            Append2SN("USE T-TEST\r" + capturehistory(hs_rn, 0) )
            statsttest x1, x2
            break
        case 1:
            Append2SN("USE K-S TEST\r" + capturehistory(hs_rn, 0))
            statskstest x1, x2
            break
        case 4:
            Append2SN("USE paired T-TEST\r" + capturehistory(hs_rn, 0))
            statsttest /PAIR x1, x2
            break
        case 3:
            Append2SN("USE Wilcoxon Signed Rank Test\r" +capturehistory(hs_rn, 0))
            StatsWilcoxonRankTest /WSRT  x1, x2
            break
    endswitch
    Append2SN(CaptureHistory(hs_rn, 1))
    effect_size(x1, x2)
END
Menu "Macros"
    "2 waves analysis", Make2WaveSelectorPanel()
END
