A simple panel for statistical comparison of two 1D waves
#include <WaveSelectorWidget> Function Make2WaveSelectorPanel() String panelName = "WaveSelectorExample" // figure out what to show in the Wave Selector, and make an appropriate name for the panel panelName+="Waves" if (WinType(panelName) == 7) // if the panel already exists, show it DoWindow/F $panelName else // doesn't exist, make it NewPanel/N=$panelName/W=(181,179,471,510) as "Wave Selector Example" // list box control doesn't have any attributes set on it ListBox ExampleWaveSelectorList,pos={9,13},size={273,241} // This function does all the work of making the listbox control into a // Wave Selector widget. Note the optional parameter that says what type of objects to // display in the list. MakeListIntoWaveSelector(panelName, "ExampleWaveSelectorList", content = WMWS_Waves) PopupMenu sortKind, pos={9,270},title="Sort Waves By" MakePopupIntoWaveSelectorSort(panelName, "ExampleWaveSelectorList", "sortKind") // This is an extra bonus- you can create your own function to be notified of certain events, // such as a change in the selection in the list. WS_SetNotificationProc(panelName, "ExampleWaveSelectorList", "ExtExampleNotification", isExtendedProc=1) // To support this demo, provide a button that displays this code Button Gr2Comp,pos={9,300},size={110,20},proc=gr2stat_0,title="2 Group" Button GrPairComp,pos={130,300},size={110,20},proc=gr2stat_1,title="Pair" endif End Function gr2stat_0(ba) : ButtonControl STRUCT WMButtonAction &ba switch( ba.eventCode ) case 2: // mouse up comp2(1)// click code here break case -1: // control being killed break endswitch return 0 End Function gr2stat_1(ba) : ButtonControl STRUCT WMButtonAction &ba switch( ba.eventCode ) case 2: // mouse up comp2(3)// click code here break case -1: // control being killed break endswitch return 0 End Function comp2(p2) variable p2 string w_sed = WS_SelectedObjectsList("Waveselectorexamplewaves","ExampleWaveSelectorList") string x1_n = StringFromList(0, w_sed) string x2_n = StringFromlist(1, w_sed) wave x1 = $x1_n wave x2 = $x2_n sn_nb();Append2SN_TS() Append2SN("*" + x1_n + ":\r mean = " + num2str(mean(x1)) + " sem = " + num2str(sqrt(variance(x1)/numpnts(x1))) + " n = " + num2str(numpnts(x1))) Append2SN("*" + x2_n + ":\r mean = " + num2str(mean(x2)) + " sem = " + num2str(sqrt(variance(x2)/numpnts(x2))) + " n = " + num2str(numpnts(x2))) if (p2 == 1) Append2SN("*** Compare 2 waves ***") cmp2(1, x1, x2) elseif (p2 == 3) Append2SN("*** Compare paired waves ***") cmp2(3, x1, x2) ENDIF END Function Append2SN_TS() //Time Stamp Variable stampDateTime = 1 // nonzero if we want to include stamp Variable tnow String stamp Notebook StatNote selection={endOfFile, endOfFile} tnow = datetime stamp = Secs2Date(tnow,0) + ", " + Secs2Time(tnow,0) Notebook StatNote text="\r" + "****" + stamp + "****\r" End Function Append2SN(str) //Add Log String str Notebook StatNote selection={endOfFile, endOfFile} Notebook StatNote text= str+"\r" End Function sn_nb() if (WinType("StatNote") == 5) // if StatNote already exists, show it DoWindow/F StatNote else newnotebook /n=StatNote /F=1 as "Stat Results Note" ENDIF END Function effect_size(x1, x2) wave x1, x2 variable cohen_s_d = abs(mean(x1) - mean (x2))/sqrt((variance(x1) + variance(x2))/2) Append2SN("*Effect Size:\r Cohen's d = " + num2str(cohen_s_d) + " (d = 0.2, small; 0.5, medium; 0.8, large)") END Function cmp2(p2, x1, x2) variable p2 wave x1, x2 statsjbtest/Q x1 wave W_JBResults variable nd_x1 if (W_JBResults[3] < W_JBResults[5]) Append2SN("x1 is Normal distribution") nd_x1 = 1 else Append2SN("x1 is not normal") nd_x1 = 0 ENDIF statsjbtest/Q x2 wave W_JBResults variable nd_x2 if (W_JBResults[3] < W_JBResults[5]) Append2SN("x1 is Normal distribution") nd_x2 = 1 else Append2SN("x1 is not normal") nd_x1 = 0 ENDIF statsvariancestest/Q x1, x2 wave W_statsVariancesTest variable nd_xs if (W_statsVariancesTest[2] < W_statsVariancesTest[3]) Append2SN("x1, x2 variance same") nd_xs = 1 else Append2SN("x1, x2 variance NOT same") nd_xs = 0 ENDIF variable p2w_con = (nd_x1==1 && nd_x2==1 && nd_xs==1) variable p2_final = p2 + p2w_con variable hs_rn = (CaptureHistoryStart()) switch(p2_final) case 2: Append2SN("USE T-TEST\r" + capturehistory(hs_rn, 0) ) statsttest x1, x2 break case 1: Append2SN("USE K-S TEST\r" + capturehistory(hs_rn, 0)) statskstest x1, x2 break case 4: Append2SN("USE paired T-TEST\r" + capturehistory(hs_rn, 0)) statsttest /PAIR x1, x2 break case 3: Append2SN("USE Wilcoxon Signed Rank Test\r" +capturehistory(hs_rn, 0)) StatsWilcoxonRankTest /WSRT x1, x2 break endswitch Append2SN(CaptureHistory(hs_rn, 1)) effect_size(x1, x2) END Menu "Macros" "2 waves analysis", Make2WaveSelectorPanel() END
nice contribution! very useful when exploring data.
Thanks
April 18, 2018 at 10:28 am - Permalink
