Randomized Maze Generator using Prim's Algorithm
#pragma rtGlobals=3 // Use modern global access method and strict wave access. //PRIM's ALGORITHM: RANDOMIZED MAZE GENERATOR //coded by Ian Allen, 13, June, 2013 function maze_maker(dim_x,dim_y) variable dim_x, dim_y // maze dimensions, recommended to use odd values but even does work //initiate the maze make/o/d/n=(dim_x,dim_y) maze = 1 make/o/d/n=(dim_x,dim_y) cell_logic = 0 make/o/d/n=(1,4) wall_list = 0 // [x_coord,y_coord,delta_x,delta_y] delta is where to check for the adjacent cell variable/g num_walls = 0 variable i for(i=0;i<dim_x;i+=2) maze[i][] = 0 maze[][i] = 0 endfor //newimage cell_logic newimage maze dowindow/c/w=graph0 maze_win //pick a seed cell to begin process variable x_coord = floor((enoise(.4999) + .5)*((dim_x - 2)/2)) * 2 + 1 variable y_coord = floor((enoise(.4999) + .5)*((dim_y - 2)/2)) * 2 + 1 variable wall_num print x_coord,y_coord cell_logic[x_coord][y_coord] = 1 //add the walls to the list maze_maker_add_walls(x_coord,y_coord,dim_x,dim_y) do //roll for a wall and check it wall_num = floor((enoise(.4999) + .5)*num_walls) maze_maker_check_wall(wall_num,dim_x,dim_y) while (num_walls > 0) end //---subroutine 1----// function maze_maker_add_walls(x_coord,y_coord, dim_x,dim_y) variable x_coord,y_coord, dim_x,dim_y //x y coord are cell coordinates not wall coordinates nvar num_walls wave wall_list,maze //add the walls to the list if they exist and are not edge walls if ( x_coord -1 != 0 && maze[x_coord-1][y_coord] == 0) // LEFT wall insertpoints 0,1, wall_list wall_list[0][0] = x_coord - 1 wall_list[0][1] = y_coord wall_list[0][2] = -1 wall_list[0][3] = 0 num_walls +=1 endif if ( x_coord + 1 != (dim_x -1) && maze[x_coord+1][y_coord] == 0) // RIGHT wall insertpoints 0,1, wall_list wall_list[0][0] = x_coord + 1 wall_list[0][1] = y_coord wall_list[0][2] = 1 wall_list[0][3] = 0 num_walls +=1 endif if ( y_coord - 1 != 0 && maze[x_coord][y_coord -1] == 0) // TOP wall insertpoints 0,1, wall_list wall_list[0][0] = x_coord wall_list[0][1] = y_coord -1 wall_list[0][2] = 0 wall_list[0][3] = -1 num_walls +=1 endif if ( y_coord + 1 != (dim_y -1) && maze[x_coord][y_coord +1] ==0) // BOTTOM wall insertpoints 0,1, wall_list wall_list[0][0] = x_coord wall_list[0][1] = y_coord + 1 wall_list[0][2] = 0 wall_list[0][3] = 1 num_walls +=1 endif print num_walls end //---subroutine2---// function maze_maker_check_wall(wall_num,dim_x,dim_y) variable wall_num,dim_x,dim_y nvar num_walls wave wall_list,cell_logic,maze variable x_coord = wall_list[wall_num][0] // wall coordinates variable y_coord = wall_list[wall_num][1] variable new_x = x_coord + wall_list[wall_num][2] // adjacent room coordinates variable new_y = y_coord + wall_list[wall_num][3] if (cell_logic[new_x][new_y] == 0) maze[x_coord][y_coord] = 1 //insert update command here when you figure it out doupdate/w=maze_win cell_logic[new_x][new_y] = 1 deletepoints (wall_num),1,wall_list num_walls -= 1 maze_maker_add_walls(new_x,new_y, dim_x,dim_y) else deletepoints (wall_num),1,wall_list num_walls -=1 endif end
and you will discover a problem on the Right wall (rtGlobals=3).
June 13, 2013 at 04:04 pm - Permalink
