Duplicate wave with arithmetic options
Greetings Forum,
I'm kind of new to programming with igor. I want to duplicate "wave k" to create "wave j" such that each point in "wave j" is subtracted from previous point in "wave k", something like this (image):
It doesn't have to be a duplicate, I think one can define function to make this, any ideas how?
Thanks in advance.
This can be easily done by the wave assignment in Igor Pro. You can see a demonstration by executing the above.
Here, p is the bin number of the waves, aligning the bin 1 of LHS to bin 1 of RHS, so and so forth. An assignment of Subtracted[] = Original[p] will make a bin-to-bin copy from Original to Subtracted. Now with the above, I am assigning them while doing the subtraction.
February 20, 2019 at 01:43 pm - Permalink
This, of course, uses literal wave names in the commands. If you are using this inside a function, it is likely that the names should be variable. That adds some complexity.
For information about what all those square brackets and p's are doing: DisplayHelpTopic "Waveform Arithmetic and Assignment"
I would discourage wave names that are one character as they aren't very descriptive. And i, j, k are frequently used in programming as the index variables in loops.
February 20, 2019 at 01:49 pm - Permalink
In reply to •make/o/n=20 Original=p^2 … by Sandbo
@Sandbo- be careful with point 0!
February 20, 2019 at 01:50 pm - Permalink
In reply to @Sandbo- be careful with… by johnweeks
Thanks for pointing that out lol
At first I also wondered what will happen when it goes below zero, but somehow it worked. Maybe under some situation it will complain.
February 20, 2019 at 02:05 pm - Permalink
In Igor 8 I think the "index out of bounds" error is always turned on. In some previous version, it was only on if you added
#pragma rtErrors=3
at the top of your procedure file. In old versions, the point numbers were simply clipped to the range [0, npoints), leading to some strange and hard to find bugs.
February 20, 2019 at 02:12 pm - Permalink
Before reading the comments I was trying to figure out by myself, and came up with something like this:
but the issue was the first element in J has to be 0 .....
and then with the help of my friend, wrote a do while loop as such:
Thanks a lot for your comments,
February 20, 2019 at 03:38 pm - Permalink
Just as food for thought: You can get rid of the if statement with initializing Jay2 with zero and write things more compact with a for loop.
Btw, your variables Jay1, KayP1, KayM1 and the wave 'Jay' is not used further in your function. Do they have any purpose?
February 25, 2019 at 08:57 pm - Permalink
