Calculates histogram of facet slopes in atomic force microscopy (AFM) images. See Surface and Interface Analysis 25 (1997) 74.
//Calculates a histogram of slopes of facets in AFM images. See Chatelier et al. in Surface and Interface Analysis 25 (1997) 741. //Similar to the output of Gwyddion image analysis software after selecting Data Process-->Statistics -->Slope Distribution --> Inclination (theta) //Assumes that the AFM image has been plane filtered, is loaded into a 2D wave, and has heights in nanometers Function slope_freq(w1) wave w1 variable X_index, Y_index, totalcycles=0, array_size, mini_wave_scaling=1 Prompt mini_wave_scaling, "Enter nm/point value: " // Set prompt for x-y scaling (example: this should be ~9.78 nm/point for a 512 x 512 pixel image that is 5 microns on a side) DoPrompt "nm/point", mini_wave_scaling if (V_Flag) return -1 // User canceled endif RemoveFromTable slopes, mini_x, mini_y //probably could comment out all of the remove/kill statements, but they can be useful. They will cause errors the first time the function is used. Killwaves slopes, mini_x, mini_y make/N=3 mini_x make/N=3 mini_y SetScale/P x 0,(mini_wave_scaling),"", mini_x SetScale/P x 0,(mini_wave_scaling),"", mini_y wavestats/Q w1 array_size=V_npnts make/N=((array_size^0.5-2)^2) slopes for (X_index=1; X_index<(array_size^0.5-1); X_index+=1) for (Y_index=1; Y_index<(array_size^0.5-1); Y_index+=1) mini_x=w1[Y_index][(p+X_index-1)] curvefit/Q line mini_x variable dzdx=k1 mini_y=w1[(p+Y_index-1)][X_index] curvefit/Q line mini_y variable dzdy=k1 slopes[totalcycles]=(atan((dzdx^2+dzdy^2)^0.5)/(2*pi))*360 //slopes in degrees are between the normal of the facet and the nominal sample normal totalcycles+=1 endfor endfor AppendToTable slopes Histogram/B={0,0.1,900} slopes,slopes_Hist //Bin slopes of 0-90 degrees into histogram. Typically need to duplicate slopes and slopes_Hist waves into other wavenames to save results End
