Auto-start when procedure file is compiled
Use a dynamic Menu definition to do two things:
1) Return the menu item string, as per normal.
2) Schedule the starting-up code with Execute/P.
Here's a demo. Copy and paste into the Procedure window and somehow cause compilation to occur (by, say, simply closing the Procedure window):
Menu "Macros", dynamic AutoStartMenu(),/Q,DoNormalStuff() End Function/S AutoStartMenu() // Test if auto start is needed NVAR/Z haveStarted= root:gHaveStarted if( !NVAR_Exists(haveStarted) ) Variable/G root:gHaveStarted=1 // do this now to prevent double scheduling Execute/P/Q/Z "StartUp()" endif return "Do Normal Stuff" End Function StartUp() DoAlert 0, "Starting Up" End
January 25, 2010 at 06:06 pm - Permalink
