C code to add an Interface Builder created window to an OS X XOP.
I was experimenting with Interface Builder as a way to add a window to an XOP. The XOP is responsible for opening and closing the window - IGOR doesn't know about it - and I destroy the window before control returns to IGOR. The attached files show the code that was created using Interface Builder and the C-code required in an XOP to display the window and update it, by drawing text in it.
Please note that it's a basic example, the window doesn't resize and could probably be improved.
To create the window call:
WindowPtr CreateXOPWindow(void) and store the WindowPtr somewhere.
to draw text on it at any time call:
DisplayWindowXOP1Message() then destroy the window when you've finished with it:
void DestroyXOPWindow(WindowPtr theWindow)
