User defined equation does not show up in batch curve fitting window
I need to do batch curve fitting on the 2D wave. I went through the example experiment, the procedure file in it, and also the forum post. Based on these, I tried writing two codes on the procedure file that would fit my data points; however the user defined equation does not appear on the batch curve fit window. I would appreciate any suggestion or comments on this. Here is my code.
#pragma rtGlobals=3 // Use modern global access method and strict wave access. #include <WMBatchCurveFitIM> Function FitMySpectrum(ww, xx) : FitFunc //code for the fitting of spectrum WAVE ww Variable xx Variable w1=0, w2=0, w3=0, w4=0, w5=0, w6=0, qq=0 Variable T1=0.23, S1=0.064, T2=0.09, S2=0.12, x1=1.92, x2=2.17 // local variable //CurveFitDialog/ These comments were created by the Curve Fitting dialog. Altering them will //CurveFitDialog/ make the function less convenient to work with in the Curve Fitting dialog. //CurveFitDialog/ Equation: //CurveFitDialog/ qq(xx) = (A1*(exp(0.5*(S1/T1)^2-(xx-x1)/T1))*erfc(0.707*(S1/T1-(xx-x1)/S1)))+(A2*exp(0.5*(S1/T1)^2-(xx-x2)/T2)*erfc(0.707*(S2/T2)-(xx-x2)/S2)) //CurveFitDialog/ End of Equation //CurveFitDialog/ Independent Variables 1 //CurveFitDialog/ xx //CurveFitDialog/ S1 --> Set equal to 0.064 //CurveFitDialog/ T1 --> Set equal to 0.23 //CurveFitDialog/ S2 --> Set equal to 0.12 //CurveFitDialog/ T2 --> Set equal to 0.09 //CurveFitDialog/ x1 --> Set equal to 1.92 //CurveFitDialog/ x2 --> Set equal to 2.17 //CurveFitDialog/ Coefficients 2 //CurveFitDialog/ ww[0] = A1 //CurveFitDialog/ ww[1] = A2 return (ww[0]*(exp(0.5*(S1/T1)^2-(xx-x1)/T1))*erfc(0.707*(S1/T1-(xx-x1)/S1)))+(ww[1]*exp(0.5*(S1/T1)^2-(xx-x2)/T2)*erfc(0.707*(S2/T2)-(xx-x2)/S2)) End //Second code <pre><code class="language-igor"> Function FitMySpectrum(ww, xx) : FitFunc //code for the fitting of spectrum WAVE ww Variable xx Variable w1=0, w2=0, w3=0, w4=0, w5=0, w6=0, qq=0 Variable T1=0.23, S1=0.064, T2=0.09, S2=0.12, x1=1.92, x2=2.17 //CurveFitDialog/ These comments were created by the Curve Fitting dialog. Altering them will //CurveFitDialog/ make the function less convenient to work with in the Curve Fitting dialog. //CurveFitDialog/ Equation: //CurveFitDialog/ qq(xx) = (A1*(exp(0.5*(S1/T1)^2-(xx-x1)/T1))*erfc(0.707*(S1/T1-(xx-x1)/S1)))+(A2*exp(0.5*(S1/T1)^2-(xx-x2)/T2)*erfc(0.707*(S2/T2)-(xx-x2)/S2)) //CurveFitDialog/ End of Equation //CurveFitDialog/ Independent Variables 1 //CurveFitDialog/ xx //CurveFitDialog/ S1 //CurveFitDialog/ T1 //CurveFitDialog/ S2 //CurveFitDialog/ T2 //CurveFitDialog/ x1 //CurveFitDialog/ x2 //CurveFitDialog/ Coefficients 2 //CurveFitDialog/ ww[0] = A1 //CurveFitDialog/ ww[1] = A2 // Body code w1 = exp(0.5*(S1/T1)^2-(xx-x1)/T1) w2 = erfc(0.707*(S1/T1-(xx-x1)/S1)) w3 = ww[0] w4 = exp(0.5*(S2/T2)^2-(xx-x2)/T2) w5 = erfc(0.707*(S2/T2-(xx-x2)/S2)) w6 = ww[1] qq = w3*(w1*w2)+w6*(w4*w5) return qq End
I examine the procedure file for batch curve fitting and find that it may be due to the following code:
in
December 3, 2017 at 03:24 am - Permalink
Thank you Wings. It works well after clearing the comments
December 3, 2017 at 06:52 am - Permalink
