same string and wave name in function
Function diurnal_hr()
variable i
wave d_int
string word = "diurnal_"
for(i=0;i<24;i+=1)
string di = word + num2str(i)
Make/ N = 974 $di
$di = d_int[p*24+i]
This is my function. I tried to separate the wave d_int into 24 waves. However, the wave name is in form of string. So when i compile, the 8th line, "$di = d_int[p*24+i]", was error.
Thanks so much
[quote=nicha]However, the wave name is in form of string. So when i compile, the 8th line, "$di = d_int[p*24+i]", was error.[/quote]
You have to use a wave reference here:
    variable i
    wave d_int
    for(i=0;i<24;i+=1)
        Make/N = 974 $di
        wave ww = $di
        ww = d_int[p*24+i]
A.
And if you're using 6.12 or later (I think that's when this feature was added) you can combine the WAVE declaration with the Make command:
    variable i
    wave d_int
    for(i=0;i<24;i+=1)
        Make/N = 974 $di/WAVE=ww
        ww = d_int[p*24+i]
