Multiple Wave Renaming
xavsd
is there any way to program a function to rename a number of waves?
for example: "air_SeparationXXXX", to "A_SeparationXXXX"
for XXXX= 0000, 0500
so as to avoid to rename them one by one by the Data--> Rename.. browser..
thanx,
xavier
March 26, 2008 at 05:53 am - Permalink
After typing RePrefix(air,a) in the command line, I get the following Syntax Error: "expected string variable or string function"
Is the procedure well built? Do you have any idea of the cause of this error?
March 31, 2008 at 03:22 am - Permalink
March 31, 2008 at 05:34 am - Permalink
Unless air and a are global string variables, that is the cause of the error message you're getting.
Try either of the following:
or
March 31, 2008 at 05:56 am - Permalink
March 31, 2008 at 07:57 am - Permalink
