Missing parenthesis
Hi everyone,
I´m having a little problem with my procedure. I want to use a window for calculating a normalization factor for a chosen wave, and then apply this normalization factor to a set of waves, selected in another listbox. I managed to do the first part (SelectNormalizationWave part), but when I use a button for duplicating the waves that I want to normalize(Function B_Continue), I obtain the following message: "expected right parenthesis". I have modify the commands, but I still get the same error. Can somebody help me?. I attach the experiment file in case it is necessary, as well as the procedure itself.
Many thanks.
#pragma rtGlobals=1
Function Panel()
    NewDataFolder/O root:Parameters
    NewDataFolder/O root:Waves
    DFREF Ref=root:Parameters, Refw=root:Waves,Refo=root:Original
    Dowindow/K Normalization_Panel
    NewPanel /N=Normalization_Panel /M /W=(15,3,30,12)
    SetDataFolder root:Original
    String/G Ref:S_ListOfWaves; SVAR S_ListOfWaves=Ref:S_ListOfWaves
    S_ListOfWaves =WaveList("*",";","")
    Make/T/O/N=(ItemsInList(S_ListOfWaves, ";")) Ref:W_ListOfWaves/WAVE=W_ListOfWaves;
    W_ListOfWaves = StringFromList(p, S_ListOfWaves, ";")
    Make/O/N=(DimSize(Ref:W_ListOfWaves, 0)) Ref:W_WaveSelection/WAVE=W_WaveSelection
    SetDataFolder root:
    Variable/G Ref:V_NumberOfWaves;NVAR V_NumberOfWaves=Ref:V_NumberOfWaves
    V_NumberOfWaves= (DimSize(Ref:W_ListOfWaves, 0))
    SetVariable NumberOfWaves title="NumberOfWaves",noedit=1,size={130,20},bodyWidth=60,pos={320,200},limits={-inf,inf,0}, value=V_NumberOfWaves, win=Normalization_Panel
    TitleBox Range_Tittle pos={100,200},title="Range",frame=1, win=Normalization_Panel
    TitleBox WavesToNormalize pos={380,20}, title="WavesToNormalize", frame=1, win=Normalization_Panel
    TitleBox WaveBase_Tittle pos={100,20},title="WaveBase",frame=1, win=Normalization_Panel
    Variable/G Ref:V_RangeInitial; NVAR V_RangeInitial=Ref:V_RangeInitial
    SetVariable Range_From title="\\JLFrom",bodyWidth=60,highColor= (0,0,0), value=V_RangeInitial
    SetVariable Range_From lowColor= (0,0,0),frame=2,font="default"
    SetVariable Range_From pos={50,250}
    SetVariable Range_From bodyWidth=40,limits={-inf,inf,0}
    Variable/G Ref:V_RangeFinal;    NVAR V_RangeFinal=Ref:V_RangeFinal; V_RangeFinal=50
    SetVariable SV_RangeTo title="\\JLTo",bodyWidth=60,highColor= (0,0,0), value=V_RangeFinal
    SetVariable SV_RangeTo lowColor= (0,0,0),frame=2,font="default"
    SetVariable SV_RangeTo pos={150,250}
    SetVariable SV_RangeTo bodyWidth=40, limits={-inf,inf,0}
    GroupBox GB_NormSep pos={30,180},size={500,4},frame=0, win=Normalization_Panel
    Variable/G ref:V_NormalizationIntensity; NVAR V_NormalizationIntensity=ref:V_NormalizationIntensity
    SetVariable ST_Intensity pos={400,260}, title="Intensity", bodyWidth=60, limits={-inf,inf,0},win=Normalization_Panel, value=V_NormalizationIntensity,noedit=1
    ListBox LB_NormalizationWave pos={90,60}, size={80,80}, listWave=W_ListOfWaves, selWave=W_WaveSelection, mode=1, win=Normalization_Panel, proc=SelectNormalizationWave
    ListBox LB_WavesToNormalize pos={390,60},size={80,80}, listWave=W_ListOfWaves, selWave=W_WaveSelection, mode=4, win=Normalization_Panel, noproc
    Button B_Continue pos={150,290}, title="Continue", proc = B_Continue, win=Normalization_Panel
Function SelectNormalizationWave(snw)
    STRUCT WMListboxAction &snw
    if (snw.eventCode == 4) // CellSelection
        NVAR V_RangeInitial=Ref:V_RangeInitial, V_RangeFinal=Ref:V_RangeFinal,V_NormalizationIntensity=ref:V_NormalizationIntensity
        Variable/G Ref:V_NormalizationRow; NVAR V_NormalizationRow=Ref:V_NormalizationRow
        ControlInfo /W=Normalization_Panel  LB_NormalizationWave
        V_NormalizationRow = V_Value
        String/G Ref:S_NormalizationWave; SVAR S_NormalizationWave=Ref:S_NormalizationWave
        S_NormalizationWave=StringFromList(V_NormalizationRow, S_ListOfWaves , ";")
        Duplicate/O refo:$S_NormalizationWave, refw:W_Normalization/WAVE=W_Normalization
        Make/O/N=(DimSize(W_Normalization, 0)) refw:Normalization/WAVE=Normalization
        Normalization=W_Normalization; Integrate Normalization
        V_NormalizationIntensity=(Normalization[DimSize(W_Normalization,0)-V_RangeInitial]-Normalization[DimSize(W_Normalization,0)-V_RangeFinal])/(V_RangeFinal-V_RangeInitial)
    Endif
Function B_Continue()
    WAVE W_WaveSelection=Ref:W_WaveSelection
    WAVE W_ListOfWaves=Ref:W_ListOfWaves
    Variable/G Ref:V_Point; NVAR V_Point=Ref:V_Point; V_Point=0
    Variable/G Ref:V_Number; NVAR V_Number=Ref:V_Number; V_Number=0
    String/G Ref:S_wave; SVAR S_wave=Ref:S_wave; S_Wave="Ups"
    if (W_WaveSelection[V_Point] == 1)
        S_wave=StringFromList(V_Point, S_ListOfWaves)
        Duplicate/O Refo:$S_wave, Refw:$("W_Wave" + num2str(V_Number))
        V_Number +=1; V_Point +=1
        V_Point+=1
    Endif
ProcedureTest.pxp (97.38 KB)
I believe your button proc should rather look like this:
Function B_Continue(ctrlName)
     String ctrlName
    // your code
[quote=ChrLie]I believe your button proc should rather look like this:
     String ctrlName
    // your code
[/quote]
Yep, that was the problem. I changed that and now it works.
Thank you very much.
A friendly note on this problem...
This illustrates a very common misunderstanding- the form of a control action procedure must be *exactly* as shown in the documentation. That's because when something happens to a control that requires calling your procedure, Igor must put together a call to the action procedure. If you write a procedure with a different format, Igor doesn't know how to fill out the unknown parameters.
You might think that an action proc that simply has no inputs would be OK. I suppose it could be, but it would have to be written in Igor's source as a special case. That adds complexity and complexity adds the chance for bugs, so we avoid it when we don't think the added complexity adds significant additional functionality.
