Make a graph the front graph inside of a function
Is there a way to make different graphs the top graph in a function so that subsequent commands can act on this new top graph?
I have tried DoWindow /F
both as is and using Execute.
Neither seem to work. Perhaps there is something that I don't understand about DoWindow?
I have tried DoWindow /F ...[/quote]
You need to supply the name of the graph that you want to bring forward. In many cases, you can also direct commands to work on a given graph without bringing it forward. See the help for each specific command that you are trying to apply. Those commands typically have a /W=winname flag that directs the command.
April 18, 2012 at 11:07 am - Permalink
But the real answer, as jjweimer says, is to direct your commands at the correct window in the first place using /W= or, in some cases (like the various control commands like Button) win=. That really is the only way to know for sure that your commands will wind up working on the correct window. Of course, you still need the correct window name...
April 18, 2012 at 11:56 am - Permalink
Possibly you are passing the name of a string variable without using $:
For details execute:
April 18, 2012 at 04:05 pm - Permalink
