    Is it possible to Setscale by Wavelist
Hi
I'm trying to make my program more flexibility, I've got some data with many layer.
I wrote my code like following code in the first time, but if the height of layer change, I have to change all numbers in code by hand, is it possible to Setscale by Wavelist or some other function?
setscale/I x,Dates[0],Dates[(numpnts(Dates)-1)],"dat", Spd196,Spd176,Spd156,Spd136,Spd116,Spd96,Spd76,Spd56,Spd36,Spd16
setscale/I x,Dates[0],Dates[(numpnts(Dates)-1)],"dat",Dir196,Dir176,Dir156,Dir136,Dir116,Dir96,Dir76,Dir56,Dir36,Dir16
Are you writing your own procedures? It is very easy to loop trough waves or pick from a list of waves with WaveList.
Here is a start:
or
January 31, 2019 at 04:30 am - Permalink
In reply to Are you writing your own… by chozo
I agree that it would be nice if this and a few other functions could take in a string list. A route I sometimes take, when I don't want to go write a whole function for a few special cases, is to use the function at the bottom of this post. The upside is that you don't have to write code, though you would have to copy that function into a Procedure file and have it compiled in the instance of Igor. Then you could run a command like the following:
January 31, 2019 at 03:31 pm - Permalink
Thank you for your advices, function is still new to me, I usually use macro to write procedures, I'll take my time to study how to write function, thanks again.
January 31, 2019 at 05:19 pm - Permalink
I try to write a loop in function, but program return "expected assignment operator" error to me, which point at StringFromList(num,strList), did I wrote something wrong ?
January 31, 2019 at 05:51 pm - Permalink
In reply to I try to write a loop in… by LE1202
One issue is that a $ is needed:
January 31, 2019 at 07:11 pm - Permalink
In reply to One issue is that a $ is… by gsb
Thanks for your help, I'll check my program carefully.
January 31, 2019 at 09:13 pm - Permalink
Here is another way to do it, which creates a wave-reference wave and runs an operation on all waves in the wave-reference wave.
February 1, 2019 at 02:43 am - Permalink
olelytken's approach of using WAVE reference waves is, in my opinion, the "right" way to do this. If the list of waves ever gets very large, you will get much better performance if you only need to look up the wave from a name once and then use those wave references for the rest of the work.
In Igor 7 and later, you can use the ListToWaveRefWave function if you have a string list of wave names, such as what you might get from WaveList, or in gsb's example above.
As a bonus, olelytken's code above could be improved slightly by declaring MySetScale as ThreadSafe and then using the MultiThread keyword in the wave assignment statement in Test(). Here's the modified code:
February 1, 2019 at 09:02 am - Permalink
Ooops, forgot the $ in my original post. So much for not testing my suggestions. It's probably a bit too late but anyway, if you want to read more about this execute in the command line:
DisplayHelpTopic "Converting a String into a Reference Using $"February 4, 2019 at 06:20 pm - Permalink
