    Is it possible to label x,y data points?
I have a third, text wave, that contains labels that correspond to each x,y point.
Is there a way to display (on a graph) the labels corresponding to each point?
I know I could manually "add annotation" for each x,y point, but is there a better way to do this?
In the trace modify dialog select "markers" as the display mode.
Then in the marker symbol pop up menu, click on the "Text" button.
You can now designate the a text wave that contains the labels for all the points. It must be the same length as your x and y data.
July 14, 2010 at 10:36 am - Permalink
