igor vs. IDL
- Has someone compiled a dictionary of the Igor equivalents of common IDL commands?
- A very common programming technique in IDL is the creation of index arrays to produce subsets of other arrays, that fullfill a certain criterion. Adressing an IDL array with another array produces a new array, that is automatically created. My translation of this into Igor reads clumsy:
•make /i/u/n=1000 list •list = p // in IDL, this and the preceding statement could be cast into one •extract /indx list, mask, list <= 500 •make /i/u/n=( numpnts( mask)) sublist •sublist = list[ mask[p]] // again, in IDL sublist would be created automatically •display sublist
Is there a way to simplify?
Regards, UHe
If you don't necessarily need the index wave, you might get away with
MatrixOPdepending on your subset criteria. I think the above is equivalent tobut it's the same number of lines and the number type of the output changes.
August 31, 2016 at 05:42 am - Permalink
UHe
August 31, 2016 at 05:52 am - Permalink
MatrixOP WaveMap()
MatrixOP WaveIndexSet()
as well as the more trivial:
MatrixOP subWaveC()
MatrixOP subWaveR()
MatrixOP subRange()
August 31, 2016 at 07:32 am - Permalink
