igor vs. IDL
I am transiting from IDL ('interactive data language', a data analysis environment common e.g. in astrophysics) to Igor. Two questions:
- Has someone compiled a dictionary of the Igor equivalents of common IDL commands?
- A very common programming technique in IDL is the creation of index arrays to produce subsets of other arrays, that fullfill a certain criterion. Adressing an IDL array with another array produces a new array, that is automatically created. My translation of this into Igor reads clumsy:
•make /i/u/n=1000 list
•list = p    // in IDL, this and the preceding statement could be cast into one
•extract /indx list, mask, list <= 500
•make /i/u/n=( numpnts( mask)) sublist
•sublist = list[ mask[p]]   // again, in IDL sublist would be created automatically
•display sublist
Is there a way to simplify?
Regards, UHe
At least you can simplify to:
make/o/i/u/n=1000 list = p
make /i/u/n=( numpnts( mask)) sublist  = list[ mask[p]]
display sublist
If you don't necessarily need the index wave, you might get away with
MatrixOP
depending on your subset criteria. I think the above is equivalent to
MatrixOP/O sublist = list / greater(501,list)
WaveTransform zapInfs sublist
display sublist
but it's the same number of lines and the number type of the output changes.
MatrixOP provides other methods for creating subsets of arrays:
MatrixOP WaveMap()
MatrixOP WaveIndexSet()
as well as the more trivial:
MatrixOP subWaveC()
MatrixOP subWaveR()
MatrixOP subRange()
