Your attachment just shows some numbers and a unit, I guess? It's a bit difficult to understand what you want to do. Can you give some more details of your problem.
Use the drawing tools to draw a line approximately where you want, then double-click on the line to bring up the dialog for settings and change the coordinate system from the default plot relative to axis bottom for the X axis or axis left for the Y axis. Then you can edit the values to be precisely what you want them to be.
As an example, an X-scale bar of 0.2 units would look like this
SetDrawLayer UserFront
SetDrawEnv xcoord= bottom,ycoord= prel // X coordinate is taken from bottom axisDrawLine0.2,0.802547770700637,0.4,0.802547770700637// the .2 and .4 are start and end of line, in axis coordinatesDrawText0.233552631578948,0.78343949044586,".2 s"// 0.4 -0.2 = 0.2 of whatever units your data are scaled in
I once made a graph hook function to draw out a marquee, truncate the width to an even value and draw and label the scale bar where the marquee was.
Here it is. It does both X and Y, as in your example. I had it draw the scale bar in white, cause I was placing it on images with dark background. But I just modified it to use constants for colour. Here it is red. Change all values to 0 to draw in black.
It draws in the programmer front drawing layer. If you do it multiple times, it will draw multiple scale bars. If you hold down the shift key while running it, it will clear all drawing in the programmer front layer before drawing the new scale bar.
It tries to read units from the axes, so set units for data scaling and x scaling.
make/o test = {0,1}
•setscale/Px0,1,"s" test
•setscale d 0,0, "V" test
•Display/W=(35,44,467,306) test
I think it may only work with left and bottom axes, not top and right, or other, user-defined axes.
STATICCONSTANT kSCALBARr = 65535STATICCONSTANT kSCALBARg = 0STATICCONSTANT kSCALBARb = 0Function DrawScaleBar():GraphMarquee
//Get the marquee coordinates and calculate xsize as distance between left and rightstring vAxis = "left", hAxis = "bottom"string axes = axislist("")if((whichlistItem("left", axes, ";")) == -1)if((whichlistItem("right", axes, ";")) == -1)doAlert0, "Neither left nor right vertical axes were found."else
vAxis = "right"endifendifif((whichlistItem("bottom", axes, ";")) == -1)if((whichlistItem("top", axes, ";")) == -1)doAlert0, "Neither top nor bottom horizontal axes were found."else
hAxis = "top"endifendifstring leftAxisUnits = stringByKey("UNITS", AxisInfo("", vAxis), ":", ";")string bottomAxisUnits = stringByKey("UNITS", AxisInfo("", hAxis), ":", ";")//Get the marquee coordinates and calculate xsize as distance between left and rightGetMarquee/K $vAxis, $hAxisvariable xSize = abs((V_right - V_left))//Chop xSize to a nice round number to draw a scalebarif((xSize < 2e06)&&(xSize > 1e06))
xSize = 1e06
elseif(xSize > 5e05)
xSize = 5e05
elseif(xSize > 2e05)
xSize = 2e05
elseif(xSize > 1e05)
xSize = 1e05
elseif(xSize > 5e04)
xSize = 5e04
elseif(xSize > 2e04)
xSize = 2e04
elseif(xSize > 1e04)
xSize = 1e04
elseif(xSize > 5e03)
xSize = 5e03
elseif(xSize > 2e03)
xSize = 2e03
elseif(xSize > 1e03)
xSize = 1e03
elseif(xSize > 5e02)
xSize = 5e02
elseif(xSize > 2e02)
xSize = 2e02
elseif(xSize > 1e02)
xSize = 1e02
elseif(xSize > 5e01)
xSize = 5e01
elseif(xSize > 2e01)
xSize = 2e01
elseif(xSize > 1e01)
xSize = 1e01
elseif(xSize >5)
xSize = 5elseif(xSize >2)
xSize = 2elseif(xSize >1)
xSize = 1elseif(xSize > 5e-01)
xSize = 5e-01
elseif(xSize > 2e-01)
xSize = 2e-01
elseif(xSize > 1e-01)
xSize = 1e-01
elseif(xSize > 5e-02)
xSize = 5e-02
elseif(xSize > 2e-02)
xSize = 2e-02
elseif(xSize > 1e-02)
xSize = 1e-02
elseif(xSize > 5e-03)
xSize = 5e-03
elseif(xSize > 2e-03)
xSize = 2e-03
elseif(xSize > 1e-03)
xSize = 1e-03
elseif(xSize > 5e-04)
xSize = 5e-04
elseif(xSize > 2e-04)
xSize = 2e-01
elseif(xSize > 1e-04)
xSize = 1e-04
elseif(xSize > 5e-05)
xSize = 5e-05
elseif(xSize > 2e-05)
xSize = 2e-05
elseif(xSize > 1e-05)
xSize = 1e-05
elseif(xSize > 5e-06)
xSize = 5e-06
elseif(xSize > 2e-06)
xSize = 2e-06
elseif(xSize > 1e-06)
xSize = 1e-06
elseif(xSize > 5e-07)
xSize = 5e-06
elseif(xSize > 2e-07)
xSize = 2e-06
elseif(xSize > 1e-07)
xSize = 1e-07
elseif(xSize > 5e-08)
xSize = 5e-08
elseif(xSize > 2e-08)
xSize = 2e-08
elseif(xSize > 1e-08)
xSize = 1e-08
elseif(xSize > 5e-09)
xSize = 5e-09
elseif(xSize > 2e-09)
xSize = 2e-09
elseif(xSize > 1e-09)
xSize = 1e-09
elseif(xSize > 5e-10)
xSize = 5e-10
elseif(xSize > 2e-10)
xSize = 2e-10
elseif(xSize > 1e-10)
xSize = 1e-10
endif//The average y-position of the selected area will be horizontal position of scalebarvariable yPos = (V_bottom + V_top)/2//Draw the scalebarif(getkeyState(0)&4)SetDrawLayer/K ProgFront // using /K kills any old drawing (like previous scalebar) that might be lying aroundelseSetDrawLayer ProgFront
endifSetDrawEnv xcoord=$hAxis, ycoord=$Vaxis// need to use graph axis coordinates SetDrawEnv linethick=5SetDrawEnv linefgc= (kSCALBARr,kSCALBARg,kSCALBARb)// color = whiteDrawLine V_left, yPos, (V_left + xSize), yPos
// print scalebar length a little bit above the scale bar, so add a return on the end and middle align text for Y// center adjust text for X to position in center of scale barstring valueStr
sprintf valueStr "%.0W1P%s\r", xSize, bottomAxisUnits
SetDrawEnv textrgb= (kSCALBARr,kSCALBARg,kSCALBARb),textxjust = 1, textyjust=1, xcoord=$hAxis, ycoord=$vAxis,fstyle=1DrawText V_left + (xSize/2),yPos,valueStr
// If left and bottom axes are in different units, draw a scalebar for left axis as wellif(cmpStr(leftAxisUnits, bottomAxisUnits)!= 0)variable ySize = abs((V_bottom - V_top))variable xPos = (V_left + V_right)/2//Chop ySize to a nice round number to draw a scalebarif((ySize < 2e06)&&(ySize > 1e06))
ySize = 1e06
elseif(ySize > 5e05)
ySize = 5e05
elseif(ySize > 2e05)
ySize = 2e05
elseif(ySize > 1e05)
ySize = 1e05
elseif(ySize > 5e04)
ySize = 5e04
elseif(ySize > 2e04)
ySize = 2e04
elseif(ySize > 1e04)
ySize = 1e04
elseif(ySize > 5e03)
ySize = 5e03
elseif(ySize > 2e03)
ySize = 2e03
elseif(ySize > 1e03)
ySize = 1e03
elseif(ySize > 5e02)
ySize = 5e02
elseif(ySize > 2e02)
ySize = 2e02
elseif(ySize > 1e02)
ySize = 1e02
elseif(ySize > 5e01)
ySize = 5e01
elseif(ySize > 2e01)
ySize = 2e01
elseif(ySize > 1e01)
ySize = 1e01
elseif(ySize >5)
ySize = 5elseif(ySize >2)
ySize = 2elseif(ySize >1)
ySize = 1elseif(ySize > 5e-01)
ySize = 5e-01
elseif(ySize > 2e-01)
ySize = 2e-01
elseif(ySize > 1e-01)
ySize = 1e-01
elseif(ySize > 5e-02)
ySize = 5e-02
elseif(ySize > 2e-02)
ySize = 2e-02
elseif(ySize > 1e-02)
ySize = 1e-02
elseif(ySize > 5e-03)
ySize = 5e-03
elseif(ySize > 2e-03)
ySize = 2e-03
elseif(ySize > 1e-03)
ySize = 1e-03
elseif(ySize > 5e-04)
ySize = 5e-04
elseif(ySize > 2e-04)
ySize = 2e-01
elseif(ySize > 1e-04)
ySize = 1e-04
elseif(ySize > 5e-05)
ySize = 5e-05
elseif(ySize > 2e-05)
ySize = 2e-05
elseif(ySize > 1e-05)
ySize = 1e-05
elseif(ySize > 5e-06)
ySize = 5e-06
elseif(ySize > 2e-06)
ySize = 2e-06
elseif(ySize > 1e-06)
ySize = 1e-06
elseif(ySize > 5e-07)
ySize = 5e-06
elseif(ySize > 2e-07)
ySize = 2e-06
elseif(ySize > 1e-07)
ySize = 1e-07
elseif(ySize > 5e-08)
ySize = 5e-08
elseif(ySize > 2e-08)
ySize = 2e-08
elseif(ySize > 1e-08)
ySize = 1e-08
elseif(ySize > 5e-09)
ySize = 5e-09
elseif(ySize > 2e-09)
ySize = 2e-09
elseif(ySize > 1e-09)
ySize = 1e-09
elseif(ySize > 5e-10)
ySize = 5e-10
elseif(ySize > 2e-10)
ySize = 2e-10
elseif(ySize > 1e-10)
ySize = 1e-10
endif//Draw the scalebarSetDrawLayer ProgFront
SetDrawEnv xcoord=$hAxis, ycoord=$vAxis// need to use graph axis coordinates (this will fail if data are plotted on other axes than bottom and left)SetDrawEnv linethick=5SetDrawEnv linefgc= (kSCALBARr,kSCALBARg,kSCALBARb)// color = whiteDrawLine V_left, yPos, V_left, (yPos + ySize)// draw labelsprintf valueStr "%.0W1P%s\r", ySize, leftAxisUnits
SetDrawEnv textrgb= (kSCALBARr,kSCALBARg,kSCALBARb),textxjust = 1, textyjust=1, textrot=90, xcoord=$hAxis, ycoord=$vAxis,fstyle=1DrawText V_left ,yPos + (ySize/2),valueStr
endifend
July 10, 2014 at 07:13 pm - Permalink
jamie
July 11, 2014 at 11:39 am - Permalink
