Hook function on image disables menu functions
I have a hook function on an image, i.e.:
Function myHook(s)
    STRUCT WMWinHookStruct &s
    // get mouse position
    variable xpos =  AxisValFromPixel("", "Bottom", s.mouseLoc.h)
    variable ypos = AxisValFromPixel("", "Left", s.mouseLoc.v)
    switch(s.eventCode)
        case 3:                 // handle left mouse click
            print xpos, ypos
            break
    endswitch
    return 1
and e.g.
make/N=(100,100) M_Image = p+q
NewImage/N=TestImage M_Image
SetWindow TestImage,hook(s)=myHook
Clicking on the image prints the mouse position on that image into the history.
Now I would like to use "Save Graphics" to save the image, but clicking onto that menu option (directly after clicking on the image) does not open the expected dialog.
Is this a bug or a feature?
Your hook function is returning 1 for every possible event. That includes some menu hook events, thereby disabling the menu. You should be experiencing a complete failure of virtually everything you can do with your image plot!
I suspect you want to return 0. Are you intending to disable the various things you can do with mouse clicks in a graph?
Thanks for pointing this out! Yes, almost everything is disabled!
Rather yes. In the actual case, clicking on an image pixel reveals a spectrum that is stored along the z-axis of a 3D wave. There is no reason to do modifications to the graph. But good to know why the above happens!
You should probably go through the list of event codes and figure out exactly which you need to block.
Did you return 0 for event code 9 (enable menu) and 10 (menu)?
ChrLie wrote:
Actually now I remember that I had issues with that function before and why I returned 1:
http://www.igorexchange.com/node/5677
If the choice is between 0 and 1 then I prefer the latter, since it took me more than a year to realise the effect ;-)
I think you need to be more selective in the events for which you return 1. For the previous problem I think you can return 1 just for mouse events:
    Variable retVal = 0
    switch(s.eventCode)
            print xpos, ypos
            retVal = 1
            break
        case 4:             // mouse moved
            retVal = 1
            break;
        case 5:             // mouse up
            retVal = 1
            break;
    endswitch
    return retVal
That will prevent the appearance of a marquee or any other mouse-related stuff. It will allow the menu events.
In Igor 7 there is a UI interaction control keyword with which you can disable features of a graph on a feature-by-feature basis.
