    evaluate goodness of fit
I have a few sets of data similar to the attached one. i have fit the same set of data with both a linear function and a single exponential function. I would like to find out which of the two functions have a better goodness of fit. How can I do it easily in Igor? I know it might be a stupid question but how can I compare the two fit in a quantitative and statistically relevant way?
Thanks a lot
January 25, 2015 at 12:07 pm - Permalink
You should rather think of a good scientific model than testing functions to match your data.
("8 peaks fit an elephant - 20 a dancing elephant")
Your data is noisy (a fact - no offense :-) ). If you want to decide between two models you need better data.
Comparing the two fits in a quantitative and statistically relevant way would be checking the reliability of your model.
To address your "stupid" question (there are no stupid questions anyway): Maybe you want to have a look at http://en.wikipedia.org/wiki/Confidence_interval .
HJ
January 26, 2015 at 02:54 pm - Permalink
My eye tells me that your data don't support any interpretation beyond the simply mean of the data. That is, a constant value.
January 26, 2015 at 09:22 am - Permalink
("8 peaks fit an elephant - 20 a dancing elephant")[/quote]
I thought it was, seven parameters fit an elephant, and eight makes it tail wag.
The quote from von Neumann is however apparently stated as "With four parameters I can fit an elephant, and with five I can make him wiggle his trunk".
http://en.wikiquote.org/wiki/John_von_Neumann
http://www.nature.com/nature/journal/v427/n6972/full/427297a.html
January 26, 2015 at 05:16 pm - Permalink
January 27, 2015 at 01:58 am - Permalink
I got it from a "in house" fitting package with these numbers and I was too lazy too look up the original citation -- my apologies!
It might have been modified since sulfur oxidation on platinum was investigated by XPS: S, SO, SO2, SO3, and SO4 each a doublet. That makes 10 well motivated peaks.
On topic:
My condensed message was: A good fit does not make a correct model and a poor fit is (almost) useless.
HJ
January 27, 2015 at 02:04 am - Permalink
