Error in Global Fit
I started having errors when running the global fit package proposed in Igor.
I am not completely sure, but it seems that the problem started appearing when using the latest version (6.22A).
The error is in the else part of the following:
Wave/T ListWave = root:Packages:NewGlobalFit:NewGF_DataSetListWave
if (WaveExists(w))
ListWave[row][NewGF_DSList_YWaveCol][0] = NameOfWave(w)
ListWave[row][NewGF_DSList_YWaveCol][1] = GetWavesDataFolder(w, 2)
ListWave[row][NewGF_DSList_YWaveCol][0] = "" // this allows us to clear the data set from a row
ListWave[row][NewGF_DSList_YWaveCol][1] = ""
And when opening a blank Igor file and a global fit, the waves of the last global fit are appearing in the control panel. Is that normal?
I unistalled and reinstalled Igor on my computer but this did not help.
What is the error message?
What did you do to provoke the error?
Is it data dependent?
[quote]And when opening a blank Igor file and a global fit, the waves of the last global fit are appearing in the control panel. Is that normal?[/quote]
No, unless you are opening an Igor experiment file (.pxp extension) in which you saved a copy of the control panel.
November 15, 2012 at 09:25 am - Permalink
I have the following errors when trying to open GF panel in a .pxp file where there is already some data loaded:
- Error when adding a new data set in the GF panel:
a wave write error: "Index out of range for new wave : "NewGF_DataSetListWave"."
- Then error when trying to link the parameters:
a wave write error: "Couldn't find the given dimension item label %backColors in wave "NewGF_MainCoefListSelWave"."
Hope this can clarify!
November 16, 2012 at 02:09 am - Permalink
http://www.igorexchange.com/node/3164#comment-1
November 16, 2012 at 10:05 am - Permalink
GF worked well for some time with version 6.3. I now have 6.32 A and get again some errors in the GF. The debugger (shown below) says: Listbox error: "Size out of range" and the problem seems to be at line "ListBox NewGF_Tab0CoefList".
I can still run the GF after clicking on the green arrow, so it does not seem to be a major error.
Do you have any idea?
// ControlInfo/W=NewGlobalFitPanel NewGF_TabControl
// switch(V_value)
// case 0:
Variable listTop, listHeight, dataSetsListWidth, dataSetsListRight, coefsListleft, coefsListWidth
CalcListSizes(listTop, listHeight, dataSetsListWidth, dataSetsListRight, coefsListleft, coefsListWidth)
ListBox NewGF_DataSetsList, win=NewGlobalFitPanel#Tab0ContentPanel, pos={dataSetsListRight-dataSetsListWidth, listTop}, size={dataSetsListWidth, listHeight}
ListBox NewGF_Tab0CoefList, win=NewGlobalFitPanel#Tab0ContentPanel, pos={coefsListleft, listTop}, size={coefsListWidth, listHeight}
Groupbox NewGF_Tab0ListDragLine,win=NewGlobalFitPanel#Tab0ContentPanel, pos={dataSetsListRight+NewGF_Tab0ListGrout/2, listTop},size={1, listHeight}
// break;
// case 1:
GetWindow NewGlobalFitPanel#Tab1ContentPanel wsizeDC
Variable Width = (V_right - V_left)
Variable Height = (V_bottom - V_top)
ListBox NewGF_CoefControlList, win=NewGlobalFitPanel#Tab1ContentPanel,size={width-NewGF_CoefListWidthMargin, height-NewGF_CoefListHeightMargin}
// break;
// endswitch
July 31, 2013 at 06:46 am - Permalink
July 31, 2013 at 12:53 pm - Permalink
Then I tried with an experiment containing my normal loading data routine and deleted the whole procedure from it, leaving a blank procedure, as well as deleting all stored waves, leaving exclusively the ones I needed for the GF. This gives again the same error message.
Unloading the GF, then killing all waves in "NewGlobalFit" and "NewGlobalFit_StoredSetup" and then reloading the GF package does not help either.
Do you have any idea where could be the problem? Thanks!
August 2, 2013 at 03:06 am - Permalink
August 2, 2013 at 08:58 am - Permalink
The saved information can be deleted from the wave root:Packages:WindowCoordinates:W_windowCoordinates.
August 5, 2013 at 12:39 pm - Permalink
