Custom Wave Scaling
Hi All,
Is there a way to set a custom scaling for a wave? I have the following two waves I want to upload and plot.
Incident Energy (MeV) Correction Factor
4.8 0.984757058
5.0 0.969265976
5.5 0.951633556
6.0 0.932863556
So in this case the x range is from 4.8 MeV to 6.0 MeV.  The difference from one x value to the next is not uniform.  The difference in incident energies is either 0.2 MeV or 0.5 MeV.  If I use "change wave scaling" or "setscale" those functions scaling the index uniformly.  Is there a way to set individual scales for each index?
I could superficially achieve this by plotting Correction Factor vs Incident Energy and display graph, but that's not actually scaling anything.
Thanks in advance, I hope this is clear.
[quote]Is there a way to set individual scales for each index?[/quote]
Setting individual X values for each Y value is what XY pairs are for. So in this situation you must use an XY pair.
Execute this for details:
DisplayHelpTopic "Waveform Versus XY Data"
This is also covered in the Getting Started section. Execute:
DisplayHelpTopic "Waves - The Key Igor Concept"
