Custom Wave Scaling
j s s
Hi All,
Is there a way to set a custom scaling for a wave? I have the following two waves I want to upload and plot.
Incident Energy (MeV) | Correction Factor |
4.8 | 0.984757058 |
5.0 | 0.969265976 |
5.5 | 0.951633556 |
6.0 | 0.932863556 |
So in this case the x range is from 4.8 MeV to 6.0 MeV. The difference from one x value to the next is not uniform. The difference in incident energies is either 0.2 MeV or 0.5 MeV. If I use "change wave scaling" or "setscale" those functions scaling the index uniformly. Is there a way to set individual scales for each index?
I could superficially achieve this by plotting Correction Factor vs Incident Energy and display graph, but that's not actually scaling anything.
Thanks in advance, I hope this is clear.
Setting individual X values for each Y value is what XY pairs are for. So in this situation you must use an XY pair.
Execute this for details:
This is also covered in the Getting Started section. Execute:
November 26, 2018 at 01:23 pm - Permalink
