Constraint on a dependent variables in FuncFit
Hello
I'm currently a script to attempt a two dimensional Voigt fit, however I need to place constraints (0<=x<=1) on one of the dependent variables within the fit, specifically w[0] in the FitVoigt2D function which determines the ratio of Gaussian/Lorentzian mixing. So far I have played around with making a constraint text wave and using the /c flag for FuncFitMD without success.
Is there a way to place a constraint on one particular value in a wave? Or, as I suspect is there a more efficient way of fitting to a two dimensional Voigt that has already been written?
Regards
Jon
Function Voigt2D(thewave)
Wave thewave
Variable/g Base,GaussianFraction,PeakHeight,xOffset,xFWHM,yOffset,yFWHM,kSix
String GaussianRatio
Make/o/d/n=8 Voigt_Coef
GaussianFraction=0.5
Voigt_Coef[0]=GaussianFraction
Voigt_Coef[1]=Base
Voigt_Coef[2]=PeakHeight
Voigt_Coef[3]=xOffset
Voigt_Coef[4]=xFWHM
Voigt_Coef[5]=yOffset
Voigt_Coef[6]=yFWHM
Voigt_Coef[7]=kSix
FuncFitMD/q FitVoigt2D, Voigt_Coef, thewave
Function FitVoigt2D(w,x,y) : FitFunc
Wave w
Variable x,y
Return	w[1]+(w[0]*(w[2]*exp((-1/(2*(1-(w[7]*w[7]))))*((((x-w[3])/w[4])^2)+(((y-w[5])/w[6])^2)-((2*w[7]*(x-w[3])*(y-w[5]))/(w[4]*w[6]))))))+((1-w[0])*(w[2]/(1+(((x-w[3])/w[4])^2)+(((y-w[5])/w[6])^2))))
It sounds like you are misusing "dependent variable". I think you mean "fit coefficient". A dependent variable is the Y data you are attempting to model.
Assuming you really mean a fit coefficient, then constraint text wave would seem like the correct approach. What did you try? What went wrong?
Hi John
You're right I was referring to a fit coefficient, have displayed an attempt below, which generates the following error message:
While executing FuncFItMD, the following occurred: Received error message "unknown/inappropiate name or symbol" while evaluating "w[0]" from constrain expression "w[0]
In addition to this I made the 'GaussianFraction' variable global, constrained it and attempted to place it within the formula returned from FitVoigt2D(), which changed all of the outputted values to zero.
Regards
Jon
Wave thewave
Voigt_Coef[1]=Base
Voigt_Coef[4]=xFWHM
Voigt_Coef[6]=yFWHM
Voigt_Coef[7]=kSix
Make/o/t/n=1 T_constraints
T_constraints[0]= {"w[0]<0.99999","w[0]>0.00001"}
FuncFitMD/q FitVoigt2D, Voigt_Coef, thewave /C=T_constraints
Wave w
Variable x,y
Constraint expressions use K0, K1, etc., to represent the fit coefficients, not w[0], etc. So change
to
T_constraints[0]= {"K0<0.99999","K0>0.00001"}
