CheckBox ControlInfo doesnot work inside a mouse event
supra
I borrowed this code from utility "Drag and Drop Traces by" "RGerkin" and used it in my own program with certain modifciation and bug fixed.
I added a Checkbox named "Check5" and used it to select whether the "AppendToGraph" is with or without reverse axis.( See the code within two red horizontal dashed line.")
But Somehow this control does not work. always it choose the default unchecked option ( without reverse axis ) although it does not give any wrong message. Is it because this control is within a mouse event that’s why its not working ? or I am missing something.
CheckBox Check5, pos={300,265},size={39,14},title="Reverse Axis",value= 0 Function DragAndDropToggle() variable i string wins=winlist("*",";","WIN:1") dfref df=root:Packages:DragAndDropTraces if(!datafolderrefstatus(df)) newdatafolder /o root:Packages newdatafolder /o root:Packages:DragAndDropTraces dfref df=root:Packages:DragAndDropTraces string /g df:source,df:dest,df:trace variable /g df:lsize for(i=0;i<itemsinlist(wins);i+=1) string win=stringfromlist(i,wins) setwindow $win hook(DragAndDrop)=DragAndDropHook endfor else killdatafolder df for(i=0;i<itemsinlist(wins);i+=1) win=stringfromlist(i,wins) setwindow $win hook(DragAndDrop)=$"" endfor endif End Function DragAndDropHook(info) struct WMWinHookStruct &info dfref df=root:Packages:DragAndDropTraces if(!datafolderrefstatus(df)) return -1 endif string trace_info1=TraceFromPixel(info.mouseLoc.h,info.mouseLoc.v,"") getwindow $info.winName psizeDC variable mouseH=info.mouseLoc.h, mouseV=info.mouseLoc.v // Convert to variables. if(mouseH>v_right || mouseH<v_left || mouseV<v_top || mouseV>v_bottom) nvar /sdfr=df lsize svar /sdfr=df trace if(strlen(trace) && lsize) modifygraph /z lsize($trace)=lsize endif endif switch(info.eventCode) case 3: // Mouse down. if(strlen(trace_info1)) info.cursorCode=1 info.doSetCursor=1 string /g df:trace=stringbykey("TRACE",trace_info1), df:source=info.winName svar /sdfr=df trace string trace_info2=traceinfo(info.winName,trace,0) variable /g df:lsize=numberbykey("lsize(x)",trace_info2,"=") nvar /sdfr=df lsize if(numtype(lsize)) return -2 endif modifygraph lsize($trace)=min(10,lsize*3) endif break case 5: // Mouse up. nvar /sdfr=df lsize svar /sdfr=df trace,source if(strlen(trace) && strlen(source) && lsize) modifygraph /z/w=$source lsize($trace)=lsize endif if(!stringmatch(source,info.winName)) // Dragged from another window. wave w1=tracenametowaveref(source,trace) wave xWave = XWaveRefFromTrace(source, trace) // removefromgraph /z/w=$source $trace //--------------------------------------------------------------------------------------------------------------- Variable Conf5 ControlInfo Check5 Conf5= V_value if (Conf5) appendtograph/R /w=$info.winName w1 vs xWave else appendtograph /w=$info.winName w1 vs xWave endif //------------------------------------------------------------------------------------------------------------------ //display w1 vs xWave endif trace="" break endswitch End
V_flag = 2 for a checkbox.
June 13, 2012 at 05:08 am - Permalink
ControlInfo/W=panelname Check5 if (V_value) ... endif
June 13, 2012 at 05:53 am - Permalink
June 13, 2012 at 06:05 am - Permalink
Indeed Panel name was the problem and as Weimer suggested ControlInfo/W=panelname solved the problem
Thank you so much to all of you
June 13, 2012 at 04:49 pm - Permalink
