jjweimer Assuming both the numeric wave nwave and the text wave twave exist and are the same dimensions, a simple conversion might be ... twave = num2str(nwave[p]) See the caveats for num2str and equivalents. Other options may be required depending on the precision you desire in the conversion. -- J. J. Weimer Chemistry / Chemical & Materials Engineering, UAHuntsville Log in or register to post comments August 12, 2014 at 04:17 am - Permalink
