Igor gets stuck and no further work is possible
Anreko
All windows are still accessible but when I want to make changes an press ok nothing
will happen. The commands are still visible in the command line but there is no cursor visible
and i cannot press enter and run the command or start a makro although Igor shows 'ready' in
the left bottom corner.
I've restarted Igor and the notebook bur the proplem is still there. I couldn't find any bug reports
or further information on this problem.
Has anyone of you seen this before and found a solution?
Thanks for your help
We have not found the cause but we have found two workarounds reported to work by one of the users:
1. Run Igor as administrator.
2. Run Igor in XP compatibility mode.
To set a shortcut to run as administrator on Windows 7:
1. Create the shortcut from Igor.exe and put the shortcut on your desktop or anywhere you like.
2. Right-click the shortcut and choose Properties.
3. Click the Shortcut tab.
4. Click the Advanced button.
5. Check Run as Administrator.
6. Click OK.
7. Click OK again.
Now when you double-click the shortcut, Igor will run as administrator.
July 7, 2014 at 08:48 am - Permalink
I have no idea how a graphics driver could cause such a problem. If it does then it would seem to be a bug in the driver.
July 8, 2014 at 08:23 pm - Permalink
