Two Temperature Model
Giannis
I try to solve the two coupled differential equations (Two Temperature Model) using the igor in order to calculate the electron phonon coupling between the two systems (hot electron and phonons).
Does any body has any code written for the Two Temperature Model?
Your help in much appreciated.
Sincerely,
Giannis
I also need to solve the Two temperature model equations. Did you end up doing it by using Igor?
I'd appreciate any help.
Amalia
June 2, 2014 at 12:04 pm - Permalink
DisplayHelpTopic "Solving Differential Equations"
Copy that line, past it into Igor's command line and press Enter.
June 2, 2014 at 12:13 pm - Permalink
