How to load rows of data into waves?
I have some particularly annoying spectroscopic data that is provided as a text file (example attached). The data points are organised as rows separated by commas. My question is how would I go about getting this data formatted into waves (e.g. in the example I'd like 3 waves for rows wavelength, sample x1 and sample x2)?
Thanks a lot!
Edit: actually this isn't always the case. Sorry for the confusion!
April 11, 2014 at 07:54 am - Permalink
This shows how to use the WaveMetrics procedure file "Load Row Data.ipf" which provides the FLoadRowDataInto1DWave function. See comments in that file for details. You can use the Macros->Load Row Data menu item, added by "Load Row Data.ipf", to call the FLoadRowDataInto1DWave function.
If that does not do the trick please zip a sample file and post it along with an explanation of what you want to load from the file.
April 11, 2014 at 09:19 am - Permalink
