How can I insert hbar symbol in graph
I want to insert hbar symbol in the axis label of a graph. I can insert Greek letter choosing font to be symbol but that does not include hbar character. Also I have searched in the special character but that also does not include hbar symbol. Please tell me how can I insert hbar symbol in the axis label in the graph.
Thanks in advance.
Text \[0h\X0\S_\M\]0 More text
These unusual text commands are available in the Special menu in the Modify Axis panel.
There may be more elegant ways of achieving the result, but this should be close, at least for me running under Windows.
hth,
Kurt
March 14, 2014 at 06:00 am - Permalink
The "MT Extra" font contains the hbar symbol. This font was created by Design Science for their MathType product but it is shipped by Microsoft with many of their products (http://www.microsoft.com/typography/fonts/font.aspx?FMID=208) so you may have it. If not you would need to purchase and install it. Or, it appears that you can get it by installing the MathType demo (http://www.dessci.com/en/dl/fonts/). There may be other sources - search for "MT Extra font".
I have "MT Extra" font on my Macintosh. I suspect that I got it through Microsoft Word.
I can create an hbar symbol on an axis on my Macintosh with this command:
Label left "\\Z24\\F'MT Extra'h"
March 14, 2014 at 07:21 am - Permalink
March 15, 2014 at 05:18 am - Permalink
March 15, 2014 at 05:45 am - Permalink
Label left "\\Z24\\F'MT Extra'h"[/quote]
Thanks hordestein, it works. Fortunately in my system MT Extra font is available, though I am not using ms office or math type.
With Regards
Apurba Paul
March 18, 2014 at 12:42 am - Permalink
hth,
Kurt[/quote]
Hi Kurt, if I copy your text from above and paste in text it works. But I could not find the hbar symbol in special menu of Modify Axis panel.
With Regards
Apurba Paul
March 18, 2014 at 12:43 am - Permalink
The unusual commands in the Special menu that I was referring to are the Store Info "\[0", Recall X-position "\X0", etc. These enabled the underscore character to be superimposed as superscript on top of the h. Not elegant, but just about achieves the result.
Using a font that contains the h-bar symbol is a far better solution.
Regards,
Kurt
March 18, 2014 at 01:04 am - Permalink
