Can I control Igor with Python?
We have hundreds simulations and need to analyse the results in Igor. The each simulation's analysis operations are all the same. For example, there are 300 simulations with the name A_1, A_2...A_300. Among these simulations, the only difference is their name. If I want to analyse A_1's results, I need to open a procedure (this procedure is generated particular for A_1 because the name "A_1" is contained in the codes, for simulation A_2, there is another procedure contains "A_2"), include several other procedures from User procedure (these procedures are universal to all simulations) and do some operations(input several commends in commend window). So the analysis operations for all simulations are the same, but I don't want to do it 320 times by hand!
Is there any simple way to solve this problem? For example, write a for loop in Python and control Igor using it.
Thanks
Well you can (obviously) write in Igor Pro code which automates the analysis operation. In case you're not familiar with Igor Pro I'd suggest to take the Guided Tour inside Igor Pro.
In any case you can't use Python in Igor Pro.
Dahair,
from the sounds of it you need to modify your current procedures. If there is a procedure for A_1, A_2, ..., A_N, then a procedure needs to be rewritten to cope with a generic case. If you already have the code to analyse one of the simulations, and the analysis is the same for all of them, then it should be straightforward to write a procedure that will do all of them in one pass. Perhaps you could put the code up for one of the analyses and we could give you an idea of how to do it.
(Thomas, it is possible to call the Python interpreter from IGOR, I wrote some XOP code a while ago to do so. This was based on some work by Rick Gerkin).
A
Just to follow up on the good suggestions thus far, here is a template to consider ...
Function DoMany(nsims)
      variable nsims
      string ncurr
      variable ic
      for (ic=1;ic<nsims;ic+=1)
            sprintf ncurr, "A_%d", ic
           // load the file for this data set (write your commands here)
           // result is wave named A_1, A_2, A_3 ... or whichever in the current data folder
           wave theOne = $ncurr
           DoOne(theOne)
Function DoOne(theOne)
      wave theOne
      // write your generic analysis here
