Copying selected data from one wave into a new wave
Hi, new user here.
I have a wave with one column of numbers. I want to select all of the numbers in the wave greater than say, x, and copy them in to a new wave.
I'm basically completely lost. Thanks for your help!
Here is one way of doing it.
Hope this helps.
Function Test()
    // make some test data
    Make/O/N=10 wData={5,3,4,5,6,2,1,7,0,9}
    // copy to a 'result' wave
    Duplicate/O wData,wFilteredData
    // use conditional to set certain values to NaN
    wFilteredData[] = wFilteredData[p]>5 ? wFilteredData[p] : NaN
    // remove the NaNs
    WaveTransform zapNaNs wFilteredData
    // display the data in a table
    Edit wData,wFilteredData
Thanks for replying. I tried your suggestion and got this message:
An attempt was made to treat a text wave as if it were a numeric wave.
I didn't think I had a text wave... The example with your wData wave works though.
you can convert your data:
Make/N = (numpnts(tWave)) nWave
nWave = str2num(tWave[p])
where tWave is your text wave.
Sorry for all the questions but when I try to compile I get an error saying:
"got 'tWave' instead of a string variable or string function name"
In a function you need to tell Igor that the text wave is a text wave. Try this:
function convert(tWave, threshold)
    wave/T twave
    variable threshold
    Make/O/N=(numPnts(twave)) nwave
    nwave = str2num(twave[p])
    nwave = nwave>threshold ? nwave : NaN
    WaveTransform zapNaNs nwave
Guys, guys!
Function Test()
    // extract values > 5
    Extract wData, wFilteredData, wData > 5
JimProuty wrote:
Guys, guys!
Function Test()
hm, yes, shorter but not necessarily faster…well, at least not on large data sets ;-)
function speed1(w)
    wave w
    variable num = StartmsTimer
    Duplicate/O w nw
    Multithread nw = w > 3 ? w : NaN
    Wavetransform zapNaNs nw
    print Stopmstimer(num)/1e6
function speed2(w)
    wave w
    Extract/O w, nw, w > 3
make/N=1e7 test = enoise(5)
•speed1(test)
  0.509921
•speed2(test)
  1.08944
