Creating an "About..." window
For a project I'm working on I need to create a function that will open an "About..." window, similar to the "About Igor Pro..." option under the "Help" menu.
I can't seem to find an example of code that would carry out this action. The alternative would be to create a function that would open a seperate text file, but for simplicity I'd like to try and avoid including seperate files.
Any help with this issue would be greatly appreciated.
The panel contains a formatted notebook subwindow. It is impractical to edit it directly (and I turned it off with /OPTS), but it is practical to copy from a normal formatted Notebook window into the subwindow, and then turn write access off with /OPTS.
January 30, 2014 at 09:55 am - Permalink
