zMrkSize markers disappear
xufriedman
ModifyGraph zmrkSize(myYwave)={myZwave,*,*,1,5}
I found that when the z-wave is all the same number, then the markers all disappear. When even just one of the values in the Z-wave is changed, then all the markers appear. This is somewhat non-ideal. I can imagine that all the markers take on the minimum, or the maximum, or the middle of the range, but when they disappear, it looks like there's nothing on the graph, which isn't really true.
I suppose I could come up with a kluge along the lines of:
if (wavemax (myZwave) == wavemin (myZwave)) ModifyGraph mSize(myYwave)=1 else ModifyGraph zmrkSize(myYwave)={myZwave,*,*,1,5} endif
Are there any better suggestions?
-Matthew
The two stars mean that you are asking Igor to map the z wave minimum to marker size 1 and the z wave maximum to marker size 5. If the z wave minimum and maximum are the same this means that each marker must be both size 1 and size 5 which is impossible. The only solution that I know of is for you to specify fixed mapping values.
Here is an example:
January 19, 2014 at 09:50 pm - Permalink
-Matthew
January 21, 2014 at 07:10 am - Permalink
