How to use a String Variable as Function Name?
does anybody know how to use a string as a function name? I want to avoid a lot if switch or if-else chains and therefore directly "build" the name of a function according to the DoPrompt-String.
For example, if you type the following in the command line everything works well:
Function Test_Function(a) Variable a return a End // type the following also in the command line: String ab = "Test_Function" print $ab(2)
If I use the same concept inside a function Igor tells me "can't use $ inside a function in this way". Is there any possibility for this?
Thanks a lot
A better way is to use FUNCREFs. For example:
November 3, 2013 at 10:01 am - Permalink
I like the idea to use FUNCREF's.
November 15, 2013 at 02:27 am - Permalink
