How does overriding constant outside of main procedure file work?
I occasionally use constants in procedure files for setting certain values that I need to modify only every once in a while.
This way I can decrease the number of magic-numbers, global variables and arguments of my user functions, without losing an easy way to change certain numbers in my code, which is nice.
Recently, I have been writing a module that I will include in other procedure files and now I am trying to figure out how to use constants in them.
On one hand, I would like to write the module in such a way that, once it is complete, I don't have to modify it at all.
On the other hand, there are some numbers that I would like to change when I use it for different purposes.
To satisfy both, overriding the constant in the file which includes the module seems like a good idea, however this is not necessarily recommended in the igor pro manual.
The manual also does not give a detailed description of which non-main procedure can override the constants in which procedure.
It only says that it is decided by the order of compilation of procedure files, but doesn't say which non-main procedure becomes compiled first.
I actually tried simple tests to see how the override of constants work when I include a procedure from another non-main procedure, and under certain conditions it does work.
Is overriding a constant (or a strConstant or a function if anybody is interested) really a bad idea to do outside of the main procedure file?
And how does igor decide which procedure becomes compiled first?
You can even store the structure and recall it later. I use this in many of my independent modules with no problem.
November 13, 2013 at 05:14 pm - Permalink
One addition to jjweimer's approach would be to have in each procedure file a static function
InitializeStruct
which holds all settings/constants you might want to change. And then you can set the struct in each procedure file to your expected values.Alternatively you can also have a look at optional function parameters
November 14, 2013 at 12:57 am - Permalink
Thank you for your comments.
Using structs sounds like a fantastic idea, I will definetily check this out.
Optional parameters is something that I use quite often and yes they are handy as well.
November 15, 2013 at 01:52 am - Permalink
