USB 6008 board and a NIDAQmx 9.7.5 driver problem
jrekling
FIFO Scan:
NI-DAQmx driver error while calling function DAQmxTaskControl with DAQmx_Val_Task_Commit; device Dev1:-89133: Specified inversion cannot be satisfied, because the hardware does not support it. Extended info: Specified inversion cannot be satisfied, because
Waveform generator:
While starting Waveform Generator: NI-DAQmx driver error while calling function DAQmxCfgSampClkTiming;
device Dev1:-200077: Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Extended info:
Property: DAQmx_SampTimingType
Requested Value: DAQmx_Val_SampClk
You Can Select: DAQmx_Val_OnDemand
Task Name: Dev1AO
Status Code: -200077
Pulse train generator:
NI-DAQmx driver error while calling function DAQmxCreateCOPulseChanFreq;
device Dev1:-200430: I/O type of the physical channel does not match the I/O type required for the virtual channel you are creating.
Extended info:
Physical Channel Name: ctr0
Virtual Channel Name: Dev1/ctr0
I/O Type Required for Virtual Channel: DAQmx_Val_CO
Task Name: Dev1_CTR_0
Status Code: -200430
The USB 6008 device does not support clocked waveform generation.
The USB 6008 device does not support pulse train generation. The counters can count. That's it.
The USB 6008 device is seductively cheap but very limited. Unfortunately, you get what you pay for.
September 4, 2013 at 11:21 am - Permalink
I got the USB 6008 to get some rudimentary code up and running before getting into a better board. Which USB board would you recommend ?
Jens
September 4, 2013 at 12:35 pm - Permalink
September 4, 2013 at 01:49 pm - Permalink
