PopupWaveSelector problem after update from IGOR 6.22A to 6.32A
fr
Since the update to IGOR 6.32A, my procedures using the PopupWaveSelector generate an error on use.
Consider the following code (as minimal an example I could manage):
#pragma rtGlobals=3 // Use modern global access method and strict wave access. #include <PopupWaveSelector> Function myPanel() make /O /T /N=(2,2) listBoxMx = "" make /O /T colTitles = {"SomeWave","SomeInfo"} make /O/N=(2,2) listBoxMx_sel DoWindow /K the_Panel NewPanel /W=(1,1,300,300) as "example panel" DoWindow /C the_Panel ListBox myListBox,pos={1,1},size={299,299},frame = 2,mode = 5 ListBox myListBox, listWave = listBoxMx ListBox myListBox, selWave = listBoxMx_sel ListBox myListBox, titleWave = colTitles MakeListboxCellIntoWSPopup("the_Panel", "myListBox", 0, 0, listBoxMx, listBoxMx_sel) //converts one listbox cell into a popup wave selector End
When I execute myPanel() and try to use the listbox cell I converted into a popup wave selector, IGOR says:
Button error: "'myListBox' is not a 'Button' control"
and redirects me to the line
Button $(popInfo.hostButton), win=$hostWindow, userData(popupWSInfo)=infoStr
in PopupWaveSelector.ipf.
Is there anything I can do to fix this? Am I doing something wrong in the setup of the popup wave selector or does the code in PopupWaveSelector.ipf need an update for IGOR 6.32A?
Looking forward for your input!
ModifyControl $popInfo.hostButton, win=$hostWindow,userdata(popupWSInfo)=infoStr
This has been updated in our source control and will be fixed in the next release. Apologies.
Nate Hyde
WaveMetrics
Nate Hyde
July 31, 2013 at 01:53 pm - Permalink
July 31, 2013 at 11:59 pm - Permalink
