Conflict between Igor libraries and Measurement Computing for XOPs
What is the best solution, given I have no access to the source code for either?
Summary of errors from compile logs
1>c:\users\public\documents\measurement computing\daq\c\cbw.h(55): warning C4005: 'BADRANGE' : macro redefinition
1> c:\program files (x86)\wavemetrics\xop toolkit 6\igorxops6\xopsupport\igorerrors.h(62) : see previous definition of 'BADRANGE' (TaskId:17)
1>c:\users\public\documents\measurement computing\daq\c\cbw.h(360): warning C4005: 'IDLE' : macro redefinition
1> c:\program files (x86)\wavemetrics\xop toolkit 6\igorxops6\xopsupport\xop.h(224) : see previous definition of 'IDLE' (TaskId:17)
Expansion: header code comparisons
1) #define BADRANGE
Measurement Computing cbw.h
* C/C++ Windows header for Measurement Computing Universal Library
/* System error code */
#define BADRANGE 30 /* Invalid range specified */
IGOR igorerrors.h
// From IgorErrors.h.
#define BADRANGE 18 // insufficient range
2) #define IDLE
/* Status values */
#define IDLE 0
IGOR xop.h
// *** XOP Message Codes -- Codes passed from Igor to XOP ***
// Basic messages
#define IDLE 2 //
compile logs attached from visual studio express 2012
I would split the code into two source files, one wich handles the interfacing with measurement computing and the other one which interfaces with Igor.
And you then call functions from the other.
As in that case only the source files include the headers, there will be no symbol clash.
So it will look like
comp.cpp
comp.h
handleIgor.cpp
July 31, 2013 at 09:49 am - Permalink
Don't #include XOP headers and MCC headers in the same file. Keep your MCC routines in one or more separate files that define routines you call from XOP code. #include the MCC headers from the MCC interface files only.
Alternatively you can do this:
#include "XOPStandardHeaders.h" #undef IDLE // IDLE is also #defined by MCC #undef BADRANGE // BADRANGE is also #defined by MCC #include "MCC.h"July 31, 2013 at 11:13 am - Permalink
I'll try it.
Thanks.
July 31, 2013 at 12:17 pm - Permalink
It's not that they get individual names. It's that, for any given compilation unit (.cpp file) these macros are defined only once. They have one definition in XOP source files and other definition in MCC source files.
Macros (created by #define) exist only from the time the compiler sees the #include directive in a given file until the end of the compilation for that file.
July 31, 2013 at 02:07 pm - Permalink
