Basic Programming Issue
Function AnalyzeParticles() TutorialCleanup() Duplicate/O root:images:screws screws NewImage screws screws=screws==163 ? 255:0 ImageMorphology /O/I=2/E=1 binarydilation screws ImageMorphology /O/I=2/E=1 erosion screws ImageAnalyzeParticles/E/W/Q/M=3/A=5/F/B stats, screws NewImage root:images:screws AutoPositionWindow/E $WinName(0,1) AppendToGraph/T W_BoundaryY vs W_BoundaryX AppendToGraph/T W_SpotY vs W_SpotX Duplicate/O w_spotx w_index w_index=p ModifyGraph mode(W_SpotY)=3 ModifyGraph textMarker(W_SpotY)={w_index,"default",1,0,5,0.00,0.00} ModifyGraph msize(W_SpotY)=6 Display/W=(23.4,299.6,297,511.4) W_ImageObjArea vs W_ImageObjPerimeter ModifyGraph mode=3,textMarker(W_ImageObjArea)={w_index,"default",0,0,5,0.00,0.00} ModifyGraph msize=6 AutoPositionWindow/E $WinName(0,1) Make/O/N=(DimSize(M_Moments,0)) ecc ***ecc=sqrt(1-M_Moments[p][3]^2/M_Moments[p][2]^2) Display /W=(23.4,299.6,297,511.4) ecc ModifyGraph mode=3,textMarker(ecc)={w_index,"default",0,0,5,0.00,0.00} ModifyGraph msize=6 AutoPositionWindow/E $WinName(0,1) ***imageAnalyzeParticles /L=(w_spotX[9],w_spotY[9]) mark screws NewImage M_ParticleMarker displayColorClasses() End ***indicate the lines of code causing the problem Error message 1: unknown/inappropriate name or symbol Error in Procedure:AnalyzeParticles() ecc=sqrt(1-M_Moments[p][3]^2/M_Moments[p][2]^2) Error message 2: unknown/inappropriate name or symbol Error in Procedure:AnalyzeParticles() imageAnalyzeParticles /L=(w_spotX[9],w_spotY[9]) mark screws
Does anyone have any idea what could be the cause of this? Thank you all in advance.
-Jrsocas
I recommend that you try the segments that are of interest to you while running the Tutorial experiment. After that extract only the relevant commands and use those in your code. Determining the relevant commands may be difficult at first but it is an essential step in understanding how to use IGOR.
June 24, 2013 at 03:00 pm - Permalink
June 24, 2013 at 03:38 pm - Permalink
