acquiring data simultaneously on two channels via NIDAQ board
I have tried this with the scan and fifo commands(Nidaqmx) but it does not allow me to scan once the 1st channel is "busy" acquiring.
Is there a way around this or am I reduced to connecting the analog out to a physical oscilloscope?
Thanks for your time.
You can have multiple channels in a single analog input scanning task. You can wire an analog output to an analog input to monitor, for instance, a generated waveform.
You cannot have two separate analog input tasks running at the same time on a single DAQ device. For that you would need a second device.
June 5, 2013 at 03:12 pm - Permalink
June 5, 2013 at 10:32 pm - Permalink
