I'm trying to do something pretty simple - take a stack of superimposed 1D waves and make a density plot showing the relative density of points. I've done some searching; am I missing a built-in way to do this in Igor or could someone give me a suggestion? I basically want the program to look at the superimposition of waves, figure out how many points are in a given box size and normalize the results. Thanks and let me know if I should provide more information. Much appreciated.
I've done something pretty similar, using a histogramming technique.
Decide how many bins you want on the x and y axes. Then go through each of your waves and decide how much 'frequency' you want to add to each bin in the density plot. You probably then need to decide how to normalise the probability along each axis.
n213 wrote: I'm trying to do something pretty simple - take a stack of superimposed 1D waves and make a density plot showing the relative density of points. I've done some searching; am I missing a built-in way to do this in Igor or could someone give me a suggestion?
I'm not sure what you mean by superimposed 1D waves, but basically what you are asking is a histogram. Igor's built-in histogram operation supports accumulating histograms from the input wave with the previous content of the histogram, using the /A flag. So, for example, if you wanted 60 boxes between -3 and +3, and your superimposed waves were called superimposed1DWave_1 through superimposed1DWave_5, something like this would do the trick:
Note that you need a lot of data points to get a nice-looking histogram, and the histogram discards a lot of detail from the data. So whereas it is certainly useful when you have a lot of poor-quality data points to reduce that information to a histogram, if you have a small number of high-quality measurements there are probably better ways to process the data. In particular, there is a one-to-one correspondence between the cumulative histogram and sorting the data points (you plot the sorted data values on the x axis and (0.5+p)/numpnts on the y axis), except that the cumulative histogram involves an extra step of rounding all the data values to the bin centers. So for calculations with histograms it is often better to express everything in terms of the cumulative histogram, and use the sorted data values as your best guess at what the cumulative histogram looks like.
In general a density plot requires a 2D histogram. Add this:
#include<Bivariate Histogram2>
Near the top of your Procedure window (select Windows->Procedure Windows->Procedure Window) and close the window. Now you have Bivariate Histogram in your Macros menu. To learn how to use it, see documentation in comments at the top of the code. Select Windows->Procedure Windows->Bivariate Histogram 2.ipf.
If your data are in a bunch of 1D waves, you will need to concatenate them into a single 1D XY pair. You can use the Concatenate operation to do that:
Concatenate/NP {wave1, wave2, ...} destWave
If your waves have some systematic naming convention, you can use WaveList to generate the list of waves needed for this. For instance, if the waves follow the naming convention wave, you might do this:
Thanks all for the suggestions, but that is not exactly what I want to do. Here's a link to an image that shows on the left what my data looks like and on the right, the sort of density plot I'm trying to get.
n213 wrote: Thanks all for the suggestions, but that is not exactly what I want to do. Here's a link to an image that shows on the left what my data looks like and on the right, the sort of density plot I'm trying to get.
I think John already gave the answer. You'll need the Bivariate Histogram package. Concatenate your force and distance waves using the /NP flag and run the Bivariate Histogram functions from the macros menu. That will give you a 2D wave which is equivalent to the figure you showed. I don't know if that works with scaled waves in case you only have one 1D data waves where the distance is set using SetScale. But you could duplicate the data wave and use something like xWave = x to have a separate x wave for that purpose.
EDIT:
try this and copy the following in the procedure window:
#include<Bivariate Histogram2>function MakeData()variableiNewDataFolder/O/S tmp
for(i=0; i<100; i+=1)Make/D/O/N=50 $"YY"+num2str(i)//make fake data wavewave w= $"YY"+num2str(i)Make/D/O/N=50 $"XX"+num2str(i)// make x data wave xw= $"XX"+num2str(i)
xw = x
w= gauss(x, (25+enoise(5)), (5+enoise(2))) +gnoise(0.02)// synthesize fake data; here a gaussian curveendforConcatenate/O/NP WaveList("YY*", ";", ""), yData
Concatenate/O/NP WaveList("XX*", ";", ""), xData
Duplicate/O yData root:yData
Duplicate/O xData root:xData
Setdatafolder root:
//KillDataFolder root:tmpend
and then execute the following commands from the command line
I think this is the right place for this request... I am hoping to do what I think is a bivariate histogram - bin two sets of time-series data (2 1-d waves) into pre-defined bins in two dimensions (a 2-d wave), but to weight to each count that should go into a bit by a third 1-d wave (on the same time basis as the two data waves).
This is (I think) equivalent to applying the 'weighting' wave in the 1-D 'histogram' command. It doesn't seem that there's way to do this with the 'Bivariate Histogram 2' procedure. Am I missing something, or does anyone have any suggestion about how to apply this functionality, or some other approach to do what I'm asking? I also looked at the 2D Joint Histogram function posted on here, but it doesn't appear to be what I need either. I can just code it, but I figured I'd try here first... Any help would be great.
Ok, it was worth asking... I'll see if I can figure out how to modify 'bivariate histogram 2' to do this, and will look out for the next version...
A.
April 30, 2013 at 05:37 pm - Permalink
May 1, 2013 at 07:57 am - Permalink
May 1, 2013 at 09:02 am - Permalink
http://ars.els-cdn.com/content/image/1-s2.0-S0969212605000195-gr2.jpg
May 1, 2013 at 05:35 pm - Permalink
EDIT:
If I understood correctly, this is what you want.
May 2, 2013 at 02:13 am - Permalink
September 25, 2013 at 06:29 pm - Permalink
September 26, 2013 at 09:24 am - Permalink
IP7 has a built in multi-dimensional JointHistogram operation.
September 26, 2013 at 09:29 am - Permalink
September 26, 2013 at 10:59 am - Permalink
In reply to by Igor
Hi guy,
How to load the multi-dimensional JointHistogram operation by using IP7?
Best regard
November 5, 2020 at 01:01 pm - Permalink
Enter and execute on the command line:
displayhelptopic "jointhistogram"November 5, 2020 at 05:43 pm - Permalink
