cross correlation lfp with calcium data
i have lfp data (sampled with 2000hz) and fluorescence data (sampled with 125 hz) and i would like to cross correlate both (to show that fluorescence changes and lfp signales are correlated). how should i handle the data in igor?
thanks,
ferand
Use the Resample dialog to increase the sampling rate of your 125 Hz data to 2000 Hz.
You can either use the "New Sampling Rate (Frequency)" to 2000,
or "Set to Same Rate as": lfp.
Select the wave to be resampled from the Wave(s) list AND CLICK the YELLOW DOWN ARROW to add the wave to the list of wave(s) to be resampled.
Then you can cross-correlate the two 2000 Hz waves.
April 12, 2013 at 05:10 pm - Permalink
My hunch would have been to downsample the 2000 Hz data to 125 Hz and then crosscorrelating the 125 Hz datasets. Is upsampling a better strategy?
April 14, 2013 at 10:27 am - Permalink
I would guess that Jim Prouty's method is better because it does not lose information from the 2000 Hz data. Properly adding interpolated points to the 125 Hz data should not significantly affect its spectral content. It adds no useful information to that signal but makes it compatible with the high-frequency data for convenient correlation methods.
April 14, 2013 at 02:23 pm - Permalink
But any high frequency features in the LFP data cannot be correlated with the fluorescence data, whether they're measurement noise or phenomenological. It's not clear to me there's any advantage to up-sampling over down-sampling here.
April 15, 2013 at 08:26 am - Permalink
I agree that the low-frequency signal will filter out high-frequency features under correlation. However it is not clear to me that down-sampling the 2000 Hz signal will be equivalent. One would have to be sure of the difference between filtering characteristics. I would opt for Jim's method because there seems to be less ambiguity in that approach. Perhaps Jim should weigh in.
April 15, 2013 at 08:50 am - Permalink
April 16, 2013 at 08:21 am - Permalink
