Global fit in a custom program
I'm currently using a custom software for a specific microscopy data analysis need.
This software is used by many users and I have to implement some feature on it but in a "user friendly" window.
For the moment, people are fitting 4 data sets individually with 4 different functions but we know that some parameters are linked between the data sets. That's why the global fit package is the solution. I have tryed to use it with success but now, I have to implement it on my user interface, with less functionnalities.
I would like to know if someone could provide me an example of a simple IGOR code which use the global fit package.
Thanks a lot in advance.
Best regards.
Sébastien
I know other customers have written custom code using DoNewGlobalFit(). Hopefully one of them will see your post and give you some pointers. You might also post a question to the mailing list: http://www.igorexchange.com/support
April 2, 2013 at 09:07 am - Permalink
I really like GlobalFit, it's really powerful. However, I was finding it a bit of a bind to setup and use.
I therefore 'rolled' my own version of global fit that works really well.
In order to provide a much easier way of doing the setup I 'rolled' my own for the trivial cases I often have to deal with. It's not hard to do if you have some coding skills.
April 4, 2013 at 07:53 am - Permalink
