Make graph with WaveName
I've a lot of data to import in a graph (~300 waves) and I don't know how to make a macro able to plot a wave vs an other just using their name.
I have a folder with X vawes : 'E_1_xxx' 'E_2_yyy' 'E_3_zzz' and an other for Y waves 'S_1_xxx' 'S_2_yyy' 'S_3_zzz' (I can merge both if necessary of course) , where xxx yyy zzz are strings containing wave's informations (same strings for same 'E' and 'S' waves number).
Is that possible to make a macro to plot 'S_1_xxx' vs 'E_1_xxx' until the total number of wave?
I am not asking for a complete code (unless you have it :) ) but just for advises and ideas !
Thanks !
1. set datafolder to the x folder. Use WaveList to get a string list of all the waves in the X folder
2. repeat step 1 for the y folder. You now have 2 strings which contain all the wave names you need.
this will make 1 graph for each xy pair. Since the two lists will be sorted in the same manner, the X and Y names should be in the correct order.
March 28, 2013 at 11:52 am - Permalink
I'll try it and keep you posted !
March 29, 2013 at 03:13 am - Permalink
March 29, 2013 at 06:07 am - Permalink
Here is the final code :
I've finally merged my two data folders, it's easier to call xnames and ynames and I display all the waves on the same graph.
In this case, all waves have the same color, so I use this code (which can be useful for someone else !) :
March 29, 2013 at 07:31 am - Permalink
March 29, 2013 at 08:36 am - Permalink
