Load data into existing wave
I want to load delimited text files which have the same amount of data columns.
I managed to load several files by one function. Each column of a file results in one wave.
But this is not what I need at the moment.
Is there an option to load the data into an existing wave?
e.g. loading the first file creates new waves, data from further files is written to the end of existing waves
This action can be compared with writing data to a data base.
LoadWave command usually overwrites the data if a wave with same name already exists.
Thank you for your answers!
This requires using a procedure. See http://www.igorexchange.com/node/3788.
March 20, 2013 at 07:05 am - Permalink
This works fine for numeric waves.
I programmed the LoadWave command to load text columns also.
In the first run text columns are loaded fine.
In the second run information from text columns is lost.
The content of my text waves is lost in this position:
Any idea?
By the way: What means "p-oldPoints"? Where is "p" coming from?
March 20, 2013 at 10:45 am - Permalink
I have added support for text waves at http://www.igorexchange.com/node/4443
I have not tested the changes. Please post here if it fails.
p is a built-in variable that represents the point number of the point in the destination wave that Igor is currently evaluating. For details execute:
March 20, 2013 at 11:09 am - Permalink
I had to delete 3 lines:
March 21, 2013 at 04:01 am - Permalink
Thanks. I have fixed that copy/paste error.
March 21, 2013 at 06:14 am - Permalink
