Image Plot directly from a 3D wave
tooprock
I have a 3D wave and want to make image plots directly from this wave. Is it possible to work directly with a 3D wave or do I need to make 2D waves from my source wave first? When I try
AppendImage
operation I get an error. Display; AppendImage dNdlogdAF[][][0] vs {binnedData_AFTimeWave, afBinList}
Thank you
NewImage dNdlogdAF
This will plot the first layer of the wave. You can then follow with, e.g.
You can also use Gizmo to display orthogonal slices of this wave.
March 18, 2013 at 08:52 am - Permalink
NewImage
operation, I can't use my data neither for x-axis nor for y-axis. I have time data for x-axis and size bins for y-axis. I just want to use the layers as matrixes for separate image plots. Do you have any suggestions for that?March 18, 2013 at 10:16 am - Permalink
Display;AppendImage dNdlogdAF vs {binnedData_AFTimeWave, afBinList}
That displays layer 0 by default. Now you can use
ModifyImage dNdlogdAF plane=<whatever>
March 18, 2013 at 10:55 am - Permalink
March 18, 2013 at 01:46 pm - Permalink
