Shaded area instead of error bars
I use such types of plots quite frequently. The workaround to calculate the "min" and "max" waves separately and use the "fill to next" feature kind of works but becomes a hassle if there's more than one set of data plotted in the same graph. Especially when traces are removed from the graph, getting the remaining ones back in order isn't easy.
A simple option to draw a shaded error area would facilitate this.
Until then, the technique of fill to next is the best we can do.
February 28, 2013 at 09:52 am - Permalink
